Old 09-03-2022, 09:10 AM   #1
Dennisfly
Dennisfly's Avatar
Default Where does this spring belong?
1935 new to me 2Dr Sedan.
The car is on jack stands and I'm underneath on a creeper cleaning, inspecting, and lubing. When i come out from underneath, I see this spring on the floor several feet behind the right rear wheel.I didn't hear anything that sounded like a spring flying off.
I checked the clutch and brake return springs, mid car, and they are both in place. The brake and clutch peddles return and feel normal. Where does this spring belong?
1929 Town Sedan (Briggs) 155B, Mitchell Overdrive
1935 Model 48 Tudor
Dennisfly is offline   Reply With Quote
Old 09-03-2022, 09:19 AM   #2
Bored&Stroked
Bored&Stroked's Avatar
Default Re: Where does this spring belong?
Looks like a brake spring to me . . . due to the thickness of it and the fact that the two ends are 180 degrees in the opposite direction. Just a wild-ass guess though!
Old 09-03-2022, 09:38 AM   #3
barnfind08
It goes in the center cross member to the mechanical brake mechanism
barnfind08 is offline   Reply With Quote
Old 09-03-2022, 09:41 AM   #4
farmertom
farmertom's Avatar
hey Dennisfly,that spring,i'd agree it looks like a brake peddle spring. notice separation right third of spring,maybe lost its tension a bit why it was replaced by prev.O maybe during relpacement was laying some where underneath finally desided to fall from it's resting place? Tom.
farmertom is offline   Reply With Quote
Old 09-03-2022, 10:57 AM   #5
Terry,OH
Terry,OH's Avatar
Does not look like any of the 35 springs. Appears to be tooo heavy for the cowl vent. all the brake springs appear different. It may have been some improper replacement put on by the previous owner. Below is the brake rod retracting spring and the clutch and brake pedal retracting springs. Look for the brake pedal, clutch pedal, brake rod retracting you may find one missing.
Old 09-03-2022, 11:46 AM   #6
JM 35 Sedan
JM 35 Sedan's Avatar
I agree with Terry. That spring doesn't look like any of the springs on my '35 coupes or sedans.
John
Old 09-04-2022, 06:50 AM   #7
Dennisfly
Dennisfly's Avatar
Talking Re: Where does this spring belong?
Thanks to all for your thoughts. I guess I might find out when I finish my work and drive the car.
I just had a thought. My lawn mower resides in the same garage although on the other side. There are several springs on the mower deck. I better check those!
1935 Model 48 Tudor
Old 09-04-2022, 11:21 AM   #8
V8COOPMAN
V8COOPMAN's Avatar
I just had a thought. My lawn mower has several springs on the mower deck.
I believe you're on to something there. Ford didn't tend to wrap the diameter of coil springs that tightly. That has the 'look' of a mower-deck spring.
Coop
This John Deere "L118 Deck Lift" spring ain't too far off.
Click Links Below __
T5 W/TORQUE TUBE
Old 09-04-2022, 10:12 PM   #9
Tinker
Tinker's Avatar
Or a screen door spring. Probably worked for a while.
Old 09-05-2022, 05:25 AM   #10
32Bee
Check to see if your cowl vent has its return spring attached.
32Bee is offline   Reply With Quote
Old 09-05-2022, 06:36 AM   #11
TerryS
TerryS's Avatar
Looks similar to the springs on my rumble seat lid?
TerryS is offline   Reply With Quote
Old 09-12-2022, 06:41 PM   #12
Vee839
Vee839's Avatar
Dennisfly,
I have an early 36 2 dr sedan. On mine, the spring should go under the passenger seat and hooked to the seat frame hardware and then to a bracket that is mounted to the floor between the front seat pivots. It keeps the unoccupied seat from pivoting forward against the dash durning a panic stop. Hope this helps.
Vee839 is offline   Reply With Quote
Old 09-12-2022, 07:22 PM   #13
Dennisfly
Dennisfly's Avatar
Vee839 thank you. I believe you are probably correct because I removed both front seats to work under the dash before I was under the car. I never saw that spring when removing the seat but the lighting was less than ideal. I'm not home right now, but when I return tomorrow, I will check for the seat spring. I'll let you know what I find.
1935 Model 48 Tudor
Old 09-14-2022, 09:21 AM   #14
Dennisfly
Dennisfly's Avatar
Vee839 - I have confirmed that you are correct. I would never have found this without your help!
1935 Model 48 Tudor
Old 09-14-2022, 11:54 AM   #15
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Vee839, could you share of pic of the right seat spring installed? Thanks!
Tim Carlig
dean333 is offline   Reply With Quote
Old 09-15-2022, 06:50 PM   #16
Vee839
Vee839's Avatar
My seats are out of my car right now, but the pictures show the eye bolt where one end of the spring attaches and where the other end attaches the bracket.
File Type: jpeg 6481C889-FAA7-4379-8FCA-BF8E55901208.jpeg (33.1 KB, 23 views)
File Type: jpeg 2277A52D-A216-4DF3-B229-DDFB2EC195EE.jpeg (34.2 KB, 24 views)
