Old 08-30-2022, 05:53 PM   #1
dad's deuce roadster
dad's deuce roadster's Avatar
Default exhaust question
Continuing with the 1950's 32 roadster restoration, we have come to the exhaust. We are looking at using Smithy's glasspacks, 22". The smallest inlet I can find is 2" ID. Did they ever make a 1.75" ID set? I ask as our consultant advised using of 1.75" exhaust pipe since being a lowboy some tight bends may be needed.
dad's deuce roadster is offline   Reply With Quote
Old 08-30-2022, 06:24 PM   #2
flatford8
flatford8's Avatar
Default Re: exhaust question
I bought Brockmans for my ‘51 and was told the same thing. The shop that bent the pipes just dealt with it.......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 08-30-2022, 07:15 PM   #3
aussie merc
aussie merc's Avatar
just have your shop reduce the rear pipe down to size where you exit the muffler ive done the same on mine works a treat you got to remember that factory was a single at 1 1/2" pipe
aussie merc is offline   Reply With Quote
Old 08-30-2022, 07:32 PM   #4
cadillac512
cadillac512's Avatar
Since 2" is so much easier to find and has far more options, I just use a bushing in the inlets/outlets of the mufflers to accommodate the 1 3/4 pipe.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 08-30-2022, 09:17 PM   #5
Terry
Thanks all. We have the 1.75 pipe and this evening I've looked around more for the 1.75 muffler. Given that Patriot which bought Smithy's doesn't show I'm guessing its gone. Meanwhile I did find that walker makes a 2" ID / 1.75" OD coupler, 3.99 at Summit. So that's the plan.
Old 08-31-2022, 08:18 AM   #6
fortyonerag
fortyonerag's Avatar
Years back an old lowrider guy told me the deal 'back in the day' was to use 2" pipe to the mufflers then 1 3/4" after that.
I tried it on an old ch#vy 6 with Smithies and it sounded pretty good - all things considered.
Not sure how a flathead would sound tho'.
fortyonerag is offline   Reply With Quote
Old 09-01-2022, 11:39 AM   #7
solidaxle
solidaxle's Avatar
Porter makes 1-3/4". Expensive but very well built.
solidaxle is offline   Reply With Quote
Old 09-01-2022, 08:51 PM   #8
Tinker
Tinker's Avatar
I'm a bit favorable to a glass pack or resonator for a bit of sound. Porter is really great.
I ran dual 2" pipes an a couple flatheads. prefer the 1.75 rap (easier to still get). Doesn't seem like a lot but is.
The trend is to go with large pipes. Look at diesel 150/300 trucks. Somehow they think they are driving a semi... which doesn't need a 6" pipe. haha Same as the coffee cans on a stock toyota civic. Sounds loud....
Old 09-02-2022, 01:13 AM   #9
cas3
Flatheads tend to run naturally quiet due the the way the exhaust is routed thru the block, as opposed to an overhead valve motor which spits out the exhaust directly from the cylinder. You would be surprised at how quiet and pleasant the sound of straight pipes from your flathead would be
Old 09-02-2022, 01:34 AM   #10
V8COOPMAN
V8COOPMAN's Avatar
Lika yay?
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 09-02-2022, 02:29 AM   #11
cas3
thats nice ! got a link coopman? I should order some up !
Old 09-02-2022, 08:45 AM   #12
solidaxle
solidaxle's Avatar
I was tempted to try these. On Amazon, search 1-3/4" glass packs.
https://m.media-amazon.com/images/W/...FXp2S._AC_.jpg
Old 09-02-2022, 04:18 PM   #13
B-O-B
B-O-B's Avatar
I don't see anything wrong with straight pipes. More reasonable also.
B-O-B is offline   Reply With Quote
Old 09-02-2022, 04:37 PM   #14
petehoovie
petehoovie's Avatar
Old 09-02-2022, 05:00 PM   #15
KiWinUS
KiWinUS's Avatar
What are mufflers?
Old 09-02-2022, 05:31 PM   #16
Kube
Super Moderator
Kube's Avatar
Originally Posted by KiWinUS View Post
What are mufflers?
What does restoration mean?
Old 09-02-2022, 09:26 PM   #17
Pech33
Pech33's Avatar
I used Smithy’s off of Amazon, the shortest I could get. The muffler shop I used (Airport Muffler in Snohomish, WA) did an excellent job, they get louder the more you drive it. I am absolutely satisfied. Free shipping too!
Pech33 is offline   Reply With Quote
Old 09-03-2022, 12:46 PM   #18
Detonator
Detonator's Avatar
Before you click "buy," make sure you have room to get a 22" muffler up in there. You may have to go shorter.
Seabright Hot Rods
Detonator is offline   Reply With Quote
Old 09-30-2022, 12:10 PM   #19
so, near a month later still deciding on the mufflers as the 22" smithy's will likely be too long. I'll update when we decide. Did take the car out for a very short spin with open Fenton headers. Needs some tuning which means getting the exhaust on.
