Old 08-30-2022, 09:51 AM   #1
guam2250
Default runaway charging
Good evening all in the Brain Trust. My '31 stock(mostly) truck developed a hole in the radiator, on a hot day. Noticed steam coming out the radiator cap and the overflow tube, towards the ground. The Boyce temperature gauge needle started dropping(no water to measure?) and the ammeter started showing an increase in charge (10 amps) with no lights on. I am using a '57 Ford, 2 brush generator with a voltage regulator hidden up under the gas tank, on the inside of the firewall. This setup has worked well for years. Why did the ammeter charge rate go up significantly with the overheated engine??? Thanks for your ideas!
guam2250 is offline   Reply With Quote
Old 08-30-2022, 10:45 AM   #2
31Tudor
31Tudor's Avatar
Default Re: runaway charging
Perhaps the steam/ water from the water flow pipe, which is close to the generator affected the voltage regulator?
31Tudor is offline   Reply With Quote
Old 08-30-2022, 11:21 AM   #3
The Master Cylinder
The Master Cylinder's Avatar
I think he mentioned the regulator is inside the cab?
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 08-30-2022, 01:10 PM   #4
guam2250
The voltage regulator is attached inside the firewall.
Old 08-30-2022, 09:13 PM   #5
eagle
eagle's Avatar
Doesn't sound like the two issues are related. Troubleshoot them independently I'd say.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 08-30-2022, 10:40 PM   #6
Synchro909
Synchro909's Avatar
Ditto. It is unusual that two separate issues arise at the same time but these cars can be cantankerous.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 08-30-2022, 10:59 PM   #7
nkaminar
nkaminar's Avatar
Probably unrelated but could be that the heat caused some electrical issues, like a increase in resistance in a connection or two or in the generator or regulator. Get out the voltmeter and measure some voltages. I am a fan of a voltmeter in the car in addition to the ammeter. The voltmeter will answer a lot of questions.
Where are you located?
Old 08-31-2022, 08:13 AM   #8
Badpuppy
Hard to connect overheating to electrical problems. Most likely an odd coincidence. Check your battery for a dead cell.
Badpuppy is offline   Reply With Quote
Old 08-31-2022, 09:13 AM   #9
Badpuppy
Could also be a failed field relay in the regulator.
Old 08-31-2022, 09:33 AM   #10
jimvette59
jimvette59's Avatar
I had the same problem with my generator in my 59 Corvette. It wasn't water just old age. I rebuilt the generator and solved the problem.
jimvette59 is offline   Reply With Quote
Old 08-31-2022, 01:59 PM   #11
guam2250
* I topped off radiator and ran the truck the next day with normal readings on ammeter and temperature gauge. This engine and A have been very stable for many years, and since things have returned to normal, I can't help but wonder if this was a high heat event. Could the heat cause the contacts, on one of the regulator coils, to stay closed and allow the generator to just keep on charging? Thanks all for the comments!
Old 08-31-2022, 02:06 PM   #12
Big hammer
Well you could try heat the regulator with a hair dryer maybe duplicate the issue, Or just go for a drive and enjoy the drive ! ��
get a bigger hammer tap done
Old 09-01-2022, 11:03 AM   #13
Badpuppy
It could be related. Might pull the regulator and put an eyeball on the field relay and look for anything unusual.
