Old 08-29-2022, 10:24 AM   #1
Admiral
Admiral's Avatar
Default Teach Me Voltage Regulators
I need to learn about voltage regulators. I understand the basics of how they function, but after reading service manuals and watching several YouTube videos I still don’t fully grasp the subject. Hopefully someone can spell things out in plain English.
  • What are common problems to look out for?
  • How do you test a voltage regulator to see if it’s working properly?
  • How do you adjust a voltage regulator so it sends the correct amount of juice to the battery?
  • Is there any maintenance you need to do?
  • What are A and B circuits?
This subject is top of mind because yesterday, my car stopped charging. I discovered the issue at the Hines Drive Cruise where I needed a jump to restart the engine. Once it was running, the electrical system (12-volt, negative ground) was not charging. Fortunately, I made it the 50 miles home on just the battery, but now I need to diagnose the charging system. Given that the generator was professionally rebuilt, I suspect the issue is in the regulator. Rather than just throwing a new regulator in and calling it a day, I'd like to actually figure out how these things work. Please learn me somethin’.
Admiral is offline   Reply With Quote
