#1 |
Is a windage tray a worthwhile addition to a modified street engine?
#2 |
Simple answer is yes
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 |
#3 |
I have looked at several designs from simple screens to elaborate designs that incorporate hinged doors etc. I intend to use the car as a street rod and I want it to be the best it can be. There is , however,a practical limit. To that end,I would appreciate some suggestions on designs that are known to function efficiently.
The engine is a 59A with a Merc crank and if it matters, a blower. Keith |
#4 |
The simplest and easiest windage tray set-up is to use an oil pan and oil pump pick-up from a 49-51 Mercury. The pan has a windage tray of sorts, although no scrapers, and the oil pump pick-up is hooded and fits down into the "hole" in the pan and basically covers the pick- up opening of the deepest part of the sump. Anything else may have to be custom made, there probably is someone who makes a windage tray for a flathead, but I am not aware of it, I haven't had to build a flathead in several years.
#5 |
No.
#6 |
#7 |
I think your answers from Ronnie Roadster and Pete would be bankable.
I dig coal, which provides motivation for EVs. |
#8 |
The best way would be to create your own custom one that closely follows the crank/rod profiles and attaches to special main-cap studs/bolts. It would take a bit of work to get it done correctly, but it is "free" horsepower so to speak!
I have a Milodon "diamond scraper" version on a higher horsepower street 383 SBC that I custom built. It puts out 520 HP and consistently builds oil-pressure on the dyno - all the way up to 6400 RPM (my redline with hydraulic rollers). The screen really helps to reduce frothing and keep oil in the pan. The dyno operator was very impressed with how the oil pressure held up after 20 dyno runs and it was obvious that the oil pump, windage tray, scraper and "kicked out" oil pan were all doing their jobs. https://www.jegs.com/i/Moroso/710/22912/10002/-1 SBC Example: https://www.jegs.com/i/Milodon/697/32270/10002/-1 Attached are the dyno stats. Doc Dec 02, 2018, 09_14.pdf Last edited by Bored&Stroked; 08-19-2022 at 08:49 AM. |
#9 |
Windage tray, crank scraper and a kick out, also pan volume increase also helps to lower windage. The longer the stroke the more this stuff helps.
Martin. |
#10 |
>>>modified street engine?>>>
Still no. 8^) |
#11 |
"I want it to be the best it can be"
Sorry don't know what "Still no 8^) " means. Martin. |
#12 |
Could you briefly explain about a "windage tray" something I know nothing about.
Appreciate some info. Phil NZ |
#13 |
#14 |
Thanks for the input. It looks like I will have to fabricate my own. It doesn't look too difficult (famous last words). I do wonder about the clearance between the tray and the crank/rod rotating assembly. Is there an optimal dimension? Or is it not critical?
Keith |
#15 |
From everything I've always heard, the closer the better . . . just make sure the assembly is rigid enough to not flex and get caught up in the rotating assembly. You'll notice on the link I posted that the Milodon diamond scraper has reinforcing materials in various places - it does not flex in the least.
#16 |
Sure, it'll help a bit, but why bother? No sense in being humiliated by a kid with a "fart-can" Honda.
#17 |
I did notice the design features of the Milodon windage tray and thought I might incorporate something similar. I will hold minimal clearance on the crank and rods and use 14or 16Ga.for reinforcement. I believe that should be ridgid enough to maintain its integrity.
Keith |
#18 | |
![]() Quote:
#19 | |
![]() Quote:
I realize your working with a 59A style oil pan. To help with a design for the latter 8ba block Ford actual made an oil pan that includes a complete windage tray assembly it was used on Mercury engines which of course also had the 4 inch stroke crankshafts. If you were able to look at the Mercury oil pan Ford used on the latter 8BA block you will see a perfect example of what to do. The oil pump pickup for this oil pan is an added bonus which you could use on the 59A. The pickup includes metal around the pickup screen area that helps add further windage protection. You could actually use that Mercury pick up with your oil pump and have a good start on what to design around the factory part. For those who may feel this is a foolish idea take a moment and wonder why Ford would go to all the trouble of designing and including such a foolish idea for a stock flathead. There's actually a simple answer because it actually works. I know on my engines it works heck even the tuners who loose when racing against me know this as well. Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 Last edited by Ronnieroadster; 08-21-2022 at 07:51 PM. |
#20 |
Ronnie is describing the oil pan I recommended. You can use this pan and pick-up as is, and it will be better than most stock pans. If you want it could be easily further modified depending on the level of performance you are trying to build to. in my opinion for an almost stock to very mild street eng. this pan is the best for the amount of money and time you would have to invest.
