08-17-2022, 01:16 PM | #1 |
Remove 1 ton rear brake removal
Need to replace some leaking wheel cylinders and get the brakes buttoned up. Anyone have a tutorial on how to remove these rears? 39 tonner
08-17-2022, 02:10 PM | #2 |
Re: Remove 1 ton rear brake removal
!st, place a small drain pan under the end to catch the bearing oil. Next, take off the 8 bolts around the end of the axle. A good whack on the end will usually pop the axle loose. Inside you will find two large nuts with a lock tab holding them. Often times there is not clearance for a normal socket in there so then you need to get one of the thin steel sockets just for this. You may find the last guy took it off with a chisel. Once those nuts are off, the bearing falls out, and the drum slides off.
08-17-2022, 02:13 PM | #3 |
Should be 3 screws holding drum to hub. If you can't take those out, remove rear axle shaft, bearing retainer nuts, bearings, and slide whole hub/drum off. The axle flange has cone washers, which require you to pound on flange to get them out. May have to back off shoes if the drum has a lip.
Better to focus on removing flathead screws and slide drum off. Panther pee and an impact screw driver will be your friends
I dig coal, which provides motivation for EVs. |
08-17-2022, 03:19 PM | #4 |
Ok, got it to this point. I'll need to get a socket that fits this nut. Is it a common size? Largest I have is a 36mm from a Dodge Ram but its no where near large enough. Also, is there a torque spec when reinstalling the nut?
08-17-2022, 03:21 PM | #5 |
Forgot pic
08-17-2022, 03:23 PM | #6 |
08-17-2022, 04:22 PM | #7 |
This is what the socket looks like.
08-17-2022, 04:28 PM | #8 |
awesome, I'll run out in between the rain showers and get a measurement for size. THX
08-17-2022, 04:49 PM | #9 |
08-17-2022, 06:32 PM | #10 |
When you get the tab bent up and can get the nut off & the lock plate off, could go tighten the inner nut to observe the amount of adjustment, probably less than 1/4 turn. Then if cone and cups look good know what the adjustment should be. I always went snug and back off 1/3 turn, but that was big trucks.
08-17-2022, 07:26 PM | #11 |
I had one of those large sockets that I used for the full-floating hubs on my vintage dirt modified. I got it from Speedway Motors, but that was almost 30 years ago.
08-17-2022, 07:40 PM | #12 |
Ford actually supplied these sockets in tool kits. Hard to find. I have one and traded one to a friend. Had the M for Moore forging.
08-17-2022, 07:40 PM | #13 |
years ago many of the auto parts stores had a variety they would loan out to get the job done. Probably not any more in this world today. 4x4 guys always have them, any of those in your neighborhood ?
08-17-2022, 08:01 PM | #14 | |
08-17-2022, 08:53 PM | #15 |
I should have a NAPA number for the rear oil seal. I will be in the shop in a while and look. I usually make a gasket from a cereal box for the axle flange. Smear both sides with your choice of sealer.
08-17-2022, 09:44 PM | #16 |
08-18-2022, 06:39 AM | #17 |
Cool beans, hope it’s happy there, this best place to get info, & van pelt sales.
08-18-2022, 03:19 PM | #18 |
Got it all apart and found the rotted wheel cylinder. I'll clean everything up before assembly. Do you recommend painting anything ? What type of lubricant goes on the moving parts, can I use disc brake lube that I have?
08-18-2022, 04:41 PM | #19 |
I used to use Lubriplate #110 brake lube. Not sure whats in it but a small can has lasted me most of my life.
08-18-2022, 05:50 PM | #20 |
I have a can of brake lube, was bought and used for disc brak backing plates and glides but I assume it should work.
