Old 08-15-2022, 12:16 PM   #1
madspeed
Default 1939 Tonner brakes?
I have a newly acquired 1939 1 ton truck. The wheel cylinders are leaking and the soft lines are all dry rotted so it's time for a complete overhaul. I cannot seem to find any info that says whether the parts are the same as on the rest of the 39 lineup? Any resources that confirm whether the 1/2 ton parts are the same?
madspeed is offline   Reply With Quote
Old 08-15-2022, 12:31 PM   #2
svm99
Default Re: 1939 Tonner brakes?
The 1938 - 1946 parts book lists the front wheel cylinders as a 91A part number so same half ton or car, the rear uses a 92Y-2192 wheel cylinder which is 1 3/8" bore.
I'd check with James at Gotham City Parts or Fred at Southside Obsolete for parts.
Good luck,Paul J.
svm99 is offline   Reply With Quote
Old 08-15-2022, 01:59 PM   #3
51504bat
51504bat's Avatar
Chuck's Trucks is another good source to check with.
https://www.chuckstrucksllc.com/
(203) 288-2769
Old 08-16-2022, 12:00 PM   #4
madspeed
Thank you fellas!
