#1 |
ok stripping down a 48 for refurb need some of our experts to chime in some advice 1 what size are the holes in the emulsion tubes has anyone ever altered these if so what was the effect for the size 2 what jetting is standard and is high altitude still 3 sizes down on these 3 float level at what fuel psi with what size fuel inlet
#2 |
The 97,48 and 81 take the same emulsion tubes #36 (0.1065) and #57 (0.043) closing the small holes will effect performance make sure all holes appear to be circular in shape. Std. main Jets are .048 and #63 (0.037) power valve. Use the 0.098 inlet valve and fuel pressure between 2-2.5
#3 | |
![]() Quote:
#4 |
ok which holes are the small ones as they all appear to be the same size
#5 |
The hole through the center from one end to the other, is the larger hole
#6 |
Sal |
#7 |
so i gather putting a tap in them to extract them basicly destroys them as the bore will now be oversize
#8 |
Tapping the end with a few threads, so they can be pulled out, does not make them bad.
#9 |
They are not in there very tight. I have used a fine tipped easy out without any damage done.
Sal |
#10 |
I've pulled them out many times - sometimes I replace them with new ones from Clive (Stromberg 97). Usually they pull right out (I just tap the ends of them a bit and put a screw/nut on them to pull them out). Then I take a fine file to clean up the bore ends when they're out.
#11 | |
In the next day or two, I'm going to be removing my Stromberg 97s to replace the main jets and the power valves as mentioned in this other thread, https://www.fordbarn.com/forum/showthread.php?t=350547 This morning I've been viewing some great YouTube videos that Charlie Price recorded and. During the disassembly in Part 1 Charlie talks about looking of compression damage to the small holes and that the early emulsion tubes had 4 holes and were changed to 2 holes for later tubes.
Glenn
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat's Notes Techno-Source-for-the-1932-thru-1953-Flathead-Ford |
#12 |
I found that ALL the small holes in both the early 4 hole and later 2-hole to be 0.042", a number 58 drill bit.
Glenn
#13 |
Does anybody have any data on how well the 2 vs 4-hole versions atomize? Also wondering if one type tends to run richer/leaner than the other type?
#14 |
Also, remember that on actual 48's, you do not have the two-position accelerator rod bases - only a single location. If you have "spare" 97 style bases, you can swap them in and then have the two adjustments for fuel-rod stroke.
Note: If you do this, then make sure you have the 97 accel pump rods . . . as they are a different length than the 81/48 versions. Last edited by Bored&Stroked; 07-28-2025 at 08:10 PM. |
#15 | |
![]() Quote:
I was wondering about atomization too. I plan to use the 4-hole version as the center carb on my two carb setup. Also regarding the drill sizes, I checked as go-no-go. Trying the #57 on one of the lower longitudinal holes, the #57 would not go in on the drill bit shaft but would start on the machined portion but very tight, therefore I say #58 are correct. YMMV
