Old 08-10-2022, 08:43 PM   #1
Tim Ayers
Default Cast vs. stamped steel clam shells
I've read some folks highlighting that they've used a cast clam shell vs. a stamped one. Is one preferred over another or is just a correct restoration piece depending on the year?
Old 08-10-2022, 10:36 PM   #2
Ford Freak
Default Re: Cast vs. stamped steel clam shells
I didn't know there was 2 types. Mine is stamped. Which one is more/less common? - F F
1952 Ford F1
!956 Fairlane Club Sedan
1965 Falcon Sprint
2007 Mustang GT
Ford Freak is offline   Reply With Quote
Old 08-10-2022, 10:38 PM   #3
cas3
I've never seen a cast one either. 32-34 are one piece, but still stamped IIRC
Old 08-10-2022, 11:03 PM   #4
svm99
I believe the early '32 were forged 2 piece and then the same part shows up again in '35 for a period of time. The forged unit bears a "B" part number.
svm99 is offline   Reply With Quote
Old 08-10-2022, 11:53 PM   #5
DavidG
DavidG's Avatar
With respect, all '32-'34 cups were one-piece steel stampings. 48-4520-A1 and 48-4520-A2 are the two versions of the two-piece caps released for the '35 model year. The cast version (not forged) has the part number cast in on one half. When a part number has a number following its letter suffix, that indicates a different supplier and normally a different design with the same functionality and therefore the same basic part number. It is one of the telltales of the Ford part numbering system that has remained more or less unchanged in terms of its basics for 98 years.
It could a regional thing as I've never thought of the cast ones as particularly uncommon.
Old 08-11-2022, 04:39 AM   #6
Tim Ayers
Thanks, David. Interesting thought about being a regional thing, since this is the first time I've encountered a cast one. All of the numerous ones I've had over the years have all been stamped steel.
Old 08-11-2022, 05:35 AM   #7
Mac VP
Mac VP's Avatar
We acquire those for our core parts stock. I’d say about somewhere between a quarter and a third of them are the cast iron type. Due to the additional thickness I believe they need a slightly longer bolt to hold them together.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 08-11-2022, 05:58 AM   #8
Tim Ayers
Interesting. I wonder if this accounts for the two different lengths of those special L bolts that hold the clam shell to the trans mount. I never knew there were two lengths until I started to amass approximately 20 of them.
The longer ones were harvested from '35/'36 trans mounts.
Old 08-11-2022, 07:14 AM   #9
DavidG
DavidG's Avatar
Both the two vertically-placed bolts that hold the two halves together and the four horizontally-placed bolts with the offset heads that attach the cap to the rear of the transmission mount are longer to accommodate the greater thickness of the steel casting.
Old 08-11-2022, 07:52 AM   #10
Tim Ayers
Makes sense, sure. Thanks
Old 08-11-2022, 02:55 PM   #11
Mart
Mart's Avatar
I've got a cast pair that have 4 bolts holding them together. Maybe Pilot or some other UK origin.
Old 08-11-2022, 02:58 PM   #12
Tim Ayers
Mart,
Neat and thanks for posting. I like your use of the nuts for the four "L" bolts. Can you tell us more where you got those? I bet they help with the tight clearance in this area.
I find even the smaller diameter Ford nuts can be a tight fight.
Old 08-11-2022, 02:58 PM   #13
DavidG
DavidG's Avatar
Now that is something different! Thanks for sharing it.
Old 08-11-2022, 03:03 PM   #14
Mart
Mart's Avatar
I made the nuts myself. I had some wheel spacer stud extenders that had a 7/16 UNF thread and a 5/8" hex body. It had a male thread one end and a female thread inside the hex. I cut off the external stud and turned the hex down at the base. They do work well.
Old 08-11-2022, 05:56 PM   #15
Ken/Alabama
Ken/Alabama's Avatar
The one on my 39 Zephyr was cast and had the part number cast into it. Had an 86H prefix which would be correct for Lincoln. Never seen one on a Ford.
Ken/Alabama is offline   Reply With Quote
Old 08-11-2022, 10:18 PM   #16
svm99
I’d like to respectfully add a bit more information to this discussion as is often done in these parts discussions. Attached are 2 pictures of part number B-4514 clamshells I’ve had (have) in my parts inventory. Thank you, Paul J.
File Type: jpg C4DF7EEC-D0BC-4106-8147-4A6E5AEC9E0F.jpg (23.6 KB, 25 views)
File Type: jpg 59D51680-F146-47C3-91C5-AC23E9B34398.jpg (49.0 KB, 24 views)
Old 08-12-2022, 12:19 AM   #17
cas3
Interesting double bolt thing from mart ! I have to agree with David G , it may be a regional thing. Me, being near the St Paul Mn Ford plant perhaps stamped parts was the thing here, as I've never seen a cast clam. Correct me if I'm wrong, but small parts like that were perhaps jobbed out locally.
