08-01-2022, 09:05 PM | #1 |
Snyder's drops Signal Stat 900
Just FYI for those buying turn signals, Snyder's has dropped the Signal Stat 900 from its catalog. You can still see it on the website but there's no option to buy. They've replaced it with a United Pacific chrome-plated unit. I spoke to Snyder's this morning, they said the price kept going up and, since the 900 was no longer USA-made, they wanted to offer customers a cheaper option that was, in their opinion, just as good.
You can still get the 900 from Mac's, Mike's, and from Bratton's as part of their turnkey wiring harness bundle. I know a lot of folks swear by the 900 and Snyder's website has a lot of references to it still up, so I thought this worth a mention. |
08-01-2022, 09:12 PM | #2 |
Re: Snyder's drops Signal Stat 900
Beware with the United Pacific chrome plated unit. The lever
is longer and has to be placed in a manner that will not hit the window crank. It's fine other than that. |
08-01-2022, 09:16 PM | #3 |
I got my Signal Stat 900 from Sacramento Vintage Ford as a part of a wiring harness, but that was 10+ years ago.
08-02-2022, 04:30 AM | #4 | |
I have window clearance issues with the Signal Stat 900 too. I whack my fingers on the window crank from time to time as I’m turning the steering wheel, depending on the position of the window crank. There is no perfect aftermarket signal switch. Sent from my iPhone using Tapatalk |
08-02-2022, 07:17 AM | #5 |
I align the stalk with a steering wheel spoke, with me with making sure I turn them off.
I don't have window crank handles. i must be missing something, oh ya, like windows. |
08-02-2022, 07:28 AM | #6 | |
Below are 6 pictures of two cars we have installed them on. The first car is a '29 Business Coupe that has the switch mounted onto the shift lever. The front light bulbs are mounted inside of the headlights using a separate LED due to the parking light socket being used. The additional tail lamp on the right side looks completely stock to most people and serves as the R/S turn signal. The second set of 3 shows a 'slant-windshield' Sedan that has the same Tickin thru Time unit installed yet the small micro switch assembly is hidden under the dash rail on the far left side in easy reach of the driver. If you look closely thru the headlight lens', the front amber bulbs in this unit are incandescent 1156 bulbs that are extremely bright and illuminate well (even when the headlights are on) hidden inside of the headlights. The tail lamps in this vehicle are full LED units that are very bright. The benefit of this set-up is no modern looking external lights, nor do you lose the use of the cowl lamps. Most people never pick-up on the turn signal mounted inside of the headlights. Therefore, the way these units are installed makes them almost stealth while retaining the original look of the vehicle, ...and IMHO, neither installation looks like an afterthought with a clunky out-of-place lever mounted onto the column tube. And, I have found this turn signal unit works well using all LEDs, or just incandescent bulbs, or mixed & matched type bulbs. That IMO makes these darn near perfect for a Model-A. . . |
08-02-2022, 08:38 AM | #7 |
While I was posting my remarks about the United turn signal,
I was wondering about a turn signal that was put somewhere else. I did think about it on the shifter as it would be easier and out in the open with your right hand readily available. And there it is! |
08-02-2022, 06:32 PM | #8 |
On two of my cars, I have a on-off-on toggle switch mounted on the steering column support. I make the toggle about 3-4" long. It is out of the way and if I need a replacement, they are available for next to nothing at any parts shop.
On one car, I have another on-off toggle switch mounted along side the first one. That switch connects right and left side indicators (the rear lights are LED). With the second switch in the OFF position, everything works normally. Put it in the ON position with the indicators on, I have hazard lights. Warning lights are mounted alongside the switches so I can see them easily. I prefer this arrangement to the Signalstat 900 that was in a car I bought from the US years ago but not by much.
08-02-2022, 06:57 PM | #9 |
I think any of the turn signal units look out of place hanging off the Model A steering column. I made my own using a three position DPDT switch, probably similar to what Synchro described. It is mounted under the dash rail.
08-02-2022, 11:27 PM | #10 |
My turn signal is the manual type not available from any supplier but the man above. It does however come with a feature the others do not . It is an indicator that lets inconsiderate drivers know they are being rude. You would be surprised how often that feature gets used!
08-03-2022, 09:40 AM | #11 | |
The Master Cylinder Enjoying life at the beach in SoCal... |
08-03-2022, 08:41 PM | #12 |
I recently bought a Signal Stat 900 from a Kenworth truck parts dealer. They make them for various big trucks to plug into the wiring harness, each model a little different. You just have to cut off the terminal plug and wire up like any other. I've read too many bad reviews of those cheap chrome offshore units. The Signal Stat is well made and I think looks just fine in a Model A. If you want one, try your local big truck parts store.
08-05-2022, 12:33 AM | #13 |
I have one of the cheap chrome units installed. It did rattle like hell at first, there's no denying that.
But after I went through the entire body it's perfectly silent now, even on rough roads or high rpms. It took some time though. |
