Old 07-30-2022, 01:26 PM   #1
skeazle
Default oil return tube
I replaced my oil return tube about a year ago or less and it still leaks like crazy. Turns out that the one end of the tube was not brazed or soldered properly at the factory so I just got another one with washers and 2 rubber gaskets. Does it matter which washers I use Brass or Copper? I got both. Should I use a little permatex (or something similar) on the rubber gaskets? thanks
9on the gaskets that go on the tube? Thanks
skeazle is offline   Reply With Quote
