07-24-2022, 03:47 PM | #1 |
1937 Sedan Steering Column Colour
Were all 1937 sedan steering columns/gear levers painted the same colour or did they vary with upholstery colour?
If all the same is there a modern paint colour code/name that generally matches the original steering column and gear lever colour? Thanks in advance. |
07-24-2022, 05:32 PM | #2 |
Re: 1937 Sedan Steering Column Colour
The deluxe models had a brown steering column and the color was called Rustic Brown. The standard models had a black steering column. Which model is your car?
I think there is an earlier post by 1937sedandelivery that identified a modern paint color that matched Rustic Brown pretty accurately. The Early Ford V-8 Club's 1937 book documents the color of the various components. It is a great reference. Last edited by Zeke3; 07-24-2022 at 05:38 PM. Reason: Added question and more information. |
07-24-2022, 05:44 PM | #3 |
Thanks Zeke,
It's a Deluxe. I was fairly sure that I had seen something posted about the colour a while ago but couldn't find it. |
07-24-2022, 05:47 PM | #4 |
MEMBER EMERITUS
Lignite by Colorpak available in a can is a pretty close match.
Available at most paint shops in NZ. |
07-24-2022, 06:26 PM | #5 |
Thanks Chris, I will have a look.
07-24-2022, 08:21 PM | #6 |
