Old 07-20-2022, 11:08 PM   #1
jeepguy1948
Default Disc brakes
Has anybody figured out how to do disc brakes (front and/or rear) whike staying with wire wheels (I realize that most any set up will require the re enforcing rings).
jeepguy1948 is offline   Reply With Quote
Old 07-21-2022, 12:35 AM   #2
jack backer
Default Re: Disc brakes
Little known Model A trivia.. during development the hub of the wheel was used as the brake drum..’Cast Iron’ Charlie Sorenson, a production man, made the argument against this design seeing production.. his concern? The general public changing a tire and wheel and not adjusting the brake… it’s why the tire is easy to change with the wheel on the car.
jack backer is offline   Reply With Quote
Old 07-21-2022, 10:43 AM   #3
Charlie Stephens
A friend of mine put disc brakes on his Model A (street rod). He soon regretted it due to brake dust all over the wire wheels. Disc brakes are great if you are driving through deep water (a stream running across the highway) or down a steep hill with a trailer. Otherwise I would put Lincoln brakes (first choice) on or the early Ford brakes (1939-48).
Charlie Stephens
Old 07-21-2022, 04:23 PM   #4
john in illinois
john in illinois's Avatar
I agree with charlie. Plus discs put a lot of strain on thr front axle.
I use lincoln front and Ford rear. Near 60/40 braking front to rear. No proportioning valve to fool with.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 07-21-2022, 07:39 PM   #5
Pete
There is no dust if you get the right pads for the type of driving you do.
I have 4 wheel Wilwood discs on my 30 2 door street driver. No dust.
When I first put discs on, I had original 19 inch wire wheels. I had to modify the wheels slightly but they worked fine. I took the wheels off because of the too narrow tire footprint.
There is no more strain with discs on the front axle than any type of brake would apply to it under the same conditions.
No proportioning valve required with proper kit.
Old 07-22-2022, 10:22 AM   #6
jeepguy1948
I guess I need to point out that I did not ask if I should do it and I didn't ask if I shouldn't do it. I asked if anybody HAD done it (while staying with wire wheels (in my case '35 wire wheels)).
Old 07-23-2022, 02:04 PM   #7
Charlie Stephens
Please accept my sincere apology I was just trying to be helpful. I will try to remember not to bother you in the future with information I think might be valuable to you.
Charlie Stephens
Old 07-23-2022, 02:14 PM   #8
GeneBob
28,
I have been in contact with Mike Hoskins from your earlier thread regarding disc brakes on the Model A. He is waiting on parts but I am very interested in pursuing this once he has the parts to put a kit together. We'll see who does this first!
GeneBob is offline   Reply With Quote
Old 07-24-2022, 03:42 PM   #9
JOHNCL
I am wondering how to have disk brakes on the front axle while using 5-on-5 1/2 bolt circle wheels. I need how to do it advice.
JOHNCL is offline   Reply With Quote
Old 07-24-2022, 07:32 PM   #10
updraught
updraught's Avatar
https://www.fordbarn.com/forum/showp...0&postcount=46
updraught is offline   Reply With Quote
Old 07-24-2022, 08:41 PM   #11
nkaminar
nkaminar's Avatar
Audi had disk brakes in the 80's which were inside out. The calipers were mounted on the inside diameter of the disks while the disks were held at the outer diameter. I am wondering if something like that could be used on the Model A. The calipers could be hidden inside what would look like a drum brake. The car would appear to have the stock brakes but have disk brakes inside the drums. The wheels would be mounted as usual.
An engineering challenge for sure.
Old 07-24-2022, 10:43 PM   #12
CarlG
CarlG's Avatar
When, and if that happens, I may be up for that.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-24-2022, 11:38 PM   #13
Synchro909
Synchro909's Avatar
IMO, if the discs were mounted inside the drum, ventilation would be a problem. They would get awful hot. To ventilate them well enough would make them visible, defeating the whole purpose of putting them in the drum.
I sometimes wonder what happened to the people who asked me for directions.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 07-25-2022, 10:29 AM   #14
Jim Brierley
I have a business card from Mike Hoskins, I know nothing about him. [email protected]
it says Model A disc brakes.
Jim Brierley is offline   Reply With Quote
Old 07-25-2022, 12:39 PM   #15
nkaminar
nkaminar's Avatar
Synchro, I suppose the backing plates could be mostly open with maybe have a scoop to encourage air to flow into the brakes. Anyway, it is just fun to think about it and probably nothing will happen.
Old 07-25-2022, 01:13 PM   #16
GeneBob
From my conversation with Mike, he is waiting on parts but his kit includes discs that allow you to use Model A and other 5 on 5.5 inch wheels. He is working with a local supplier to provide custom calipers that place the bleed screw in to proper location and use readily available brake pads (maybe the metric GM?) His kit puts discs on the rear as well as the front to try to avoid the proportioning valve challenge of a disc/drum system. I don't know if he is building in any difference in piston size to bias to the front. He has built a prototype of this this on his own car. His plan is to keep it simple.
I am surprised that he has not posted to this thread but he is pretty busy.
Last edited by GeneBob; 07-25-2022 at 01:15 PM. Reason: clarify proportioning valve statement
Old 07-25-2022, 03:52 PM   #17
jack backer
The proportion valve is used to bias the braking pressure to the front, stock model a’s are biased to the rear.
Old 07-25-2022, 04:29 PM   #18
40 Deluxe
If you're keeping the 19" or 21" wheels the stock mechanical brakes are capable of sliding (locking up) the tires. If you spend a bajillion dollars on disc brakes, they too will lock up the tires. So where are the benefits? Disc brakes have better fade resistance, true, but do you really drive your stock (or nearly stock) Model A that hard??
Old 07-25-2022, 04:38 PM   #19
GeneBob
I think you would want either a proportioning valve or bigger caliper pistons or bigger discs in the front but hey, anyone can bias to the front or rear if they choose.
The advantage that I see is for people who frequently drive the car and are driving at speeds beyond the stock Model A. Nothing against a stocker that is driven within its limits but some of us are a little crazy and are always pushing for more. More speed, better tires, more brake capability with much less fade. I have definitely crossed the line into "hot rodding" the car. For those who like the stock Model A, changing to disc brakes is not even a consideration. I often wonder if I should have stayed on the other side of the line.
Old 07-25-2022, 04:44 PM   #20
jack backer
I left the purist reservation too.. 40 deluxe is on to a key element of any braking system, traction. Skidding is not maximum braking, it’s a loss of control. I run 16” ford wires and modern radials for that reason..stopping, not sliding.
