Old 07-06-2022, 06:10 AM   #1
38convsedan
38convsedan's Avatar
Default 1/4” or 5/16” Fuel Line?
My 38 has an 8BA. It has a replacement tank with 1/4” fuel lines.
I’ve read 5/16” is recommended for the 8BA.
Will replacement tank accept 5/16”?
38convsedan is offline   Reply With Quote
Old 07-06-2022, 08:15 AM   #2
Bored&Stroked
Bored&Stroked's Avatar
Default Re: 1/4” or 5/16” Fuel Line?
You'll probably not have an issue, though you could replumb the tank and put the larger line in. Also, check the fittings - as I've seen quite a few modern brass fittings with restrictions that are greater than what a 1/4" line would provide.
Old 07-06-2022, 01:49 PM   #3
19Fordy
19Fordy's Avatar
In 1972 I installed an 8BA in my 40 Ford and used the stock 1/4 inch fuel lines, except that I did remove the stock flexible cloth covered rubber fuel line that fed the carbureator. Have never had any problems. Engines runs a Holley 460 four barrel.
Old 07-06-2022, 02:41 PM   #4
mike in tucson
5/16 ID line has 1.57 times the area of 1/4 ID line. But does
the 8BA need the additional flow?
mike in tucson is offline   Reply With Quote
Old 07-06-2022, 03:18 PM   #5
Bill OH
I used 5/16ths Cu line on my 38 and connected to the original tank with the proper 5/16 inverted nut. Have not had any vapor lock problems.
Bill OH is offline   Reply With Quote
Old 07-06-2022, 05:25 PM   #6
19Fordy
19Fordy's Avatar
So it seems that both 1/4 in and 5/16 will work depending on the fuel demands of your engine.
Read this thread and check out the fittings available should you decide to change. this fellow decided to go from 1/4 to 3/8 inch.
https://www.jalopyjournal.com/forum/...o-3-8.1259369/
Old 07-06-2022, 05:26 PM   #7
Bored&Stroked
I use the NiCop line all the time . . . easy to bend/flare and works well for both fuel as well as brake line needs.
Old 07-06-2022, 07:36 PM   #8
tubman
tubman's Avatar
4160 Holley? How big? A 390 cfm?
Old 07-06-2022, 08:50 PM   #9
Jack E/NJ
Jack E/NJ's Avatar
>>>I’ve read 5/16” is recommended for the 8BA.>>>
Yes, a bigger line is preferred after you reach 88 mph.
Jack E/NJ is offline   Reply With Quote
Old 07-08-2022, 10:52 AM   #10
19Fordy
19Fordy's Avatar
Yes, it's a 4160 Holley 390 "square bore" with #51 jets. List # 8007 with manual choke. It's about 20 years old.
Here's an excellent video on the differences between a Holley 4150 and a Holley 4160 carburetor.
https://www.holley.com/blog/post/hol...rs_explained_/
I see now where you can buy a Holley Chinese made carb. Wonder how the quality is? Is anything made in the USA anymore?
https://www.google.com/search?q=chin...&bih=881&dpr=1
and
https://www.ebay.com/itm/NEW-390CFM-...-53200-19255-0
Old 07-08-2022, 02:40 PM   #11
51504bat
51504bat's Avatar
1/4" line on the 8ba in my '39 p/u. Works fine.
Old 07-08-2022, 03:13 PM   #12
Mart
Mart's Avatar
My 32 has 1/4" lines. It seems to run well at wide open throttle.
I don't know at which point 5/16" lines would become necessary, but I think a relatively stock flatty falls on the safe side of the line.
Old 07-09-2022, 10:20 AM   #13
Ol' Ron
Ol' Ron's Avatar
Not sure the size of the stock fuel line in a 46/48 ford. However we ran 370 cci Olda engine with tri carb intakes Clay smith super matchless Cam at the drags back in the late 50s. Might have gone faster with a bigger line, but didn't know any better.
Gramps
Ol' Ron is online now   Reply With Quote
