#1 |
Years ago I think I saw a "universal top kit" that could possibly be adapted to give my 1929 Coupe a fold-down soft top. Is something like that available?
#2 |
Not to say years ago there could have been some sort of cobbled up kit to do that but I have been in this hobby since the early 60's and don't recall ever seeing such a kit. What you may be thinking of is a regular top kit for a sport coupe (which does not fold down) or a kit for a cabriolet. If you chop a coupe to try to make a roadster you will end up with a mess that nobody that knows anything about Model A's will want. Specifically, the value will drop out of sight. If you want a roadster, sell your coupe and buy a roadster. Or next best thing remove the coupe body and sell it and buy a repo roadster body.
#3 |
Just thinking of a temporary thing until I can afford all the wood to rebuild my cab. In another question, I once saw a supplier that sold a metal coupe roof insert. My coupe had a home-made metal roof before I tore it all down and started over. My "Bessie" was in parts all over the property for ten years until I finally had the front crossmember welded up and a found all the parts to reassemble about three years ago. So far, I have put on 300 miles on her and have not left the town limits.
#4 |
Well reading between the lines…..
Seems like you’ve got something that you can do what ever the heck you want to. Just keep it running and have fun! |
#5 |
Friend has a '30 'roadster'. Well, sort of. Back in the 60's sometime his father took a sawzall to the top. Its been a 'roadster' ever since. He did a pretty nice job of it.
#6 |
#7 |
I've seen all sorts of coupsters over the years. Some cut them way down to the beltline and some just cut the B-pillar and window frame off. They usually never look quite right. A good customizer could build it like a Cabriolet but it would take a lot of work to make it look good.
#8 |
Wood kits expensive. Brackets are unique. I had all the original stuff with mine, lined the wood with flat bar to tighten it up.A Carson top is a reasonably cheap and easy top.
https://allstarupholsterymn.com/carson-tops/ |
#9 |
![]() I've been driving around town for three years with her like this - walkerlakeprinter |
#10 |
with cut down doors, you could almost adapt the rpu repro fold down top..........
#11 |
#12 |
"coupester" I like that name rotor. I would buy a car named that!
"Ain't but three thangs in this world worth a solitary dime, but A Models, Sweet Tea, and Macaroni Pie!" |
