06-12-2022, 06:49 PM | #1 |
#4 Rod bearing disintegrated?
I need help understanding what my options are to repair one connecting rods babbitt bearing. Is this an engine out repair or can a new bearing be poured and the piston and rod be reinstalled? I know how the babbitt is poured but I don't know what is required to fit the new bearing to the crank. We caught this early and the crank, rod and other bearings are in good condition.
Hopefully the two pictures actually attached to show the failure but It looks like the oil passage was blocked and the oil starved bearing overheated and failed. Am I on the right track or should I be looking for a bigger problem? |
06-12-2022, 08:14 PM | #2 |
Re: #4 Rod bearing disintegrated?
Re-poured rods are available from the vendors, or have that one done. It all should bolt back up if you can give correct dimensions. You don't need to pull the engine, just the head. How fast do you drive your car?
06-12-2022, 09:07 PM | #3 |
Fitting the bearing may not be needed if the rod bearing is machined very accurately. Check the clearance with Plastigauge. This can be done with the engine in the car but generally things are much easier when the engine is mounted on an engine stand in your garage or shop. You will have to measure the journal to order the correct bearing. Use a micrometer and assure that the journal is not out of round or tapered more than 0.0005. A rod bearing will fail like that if the engine is run with excessive ignition advance. Not saying that this is the case here, but a rod bearing will look like that if it is the case. The excessive advanced ignition puts a lot of stress on the rod bearing. https://www.snydersantiqueauto.com/p...d=980308&cat=0
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 06-12-2022 at 09:21 PM. |
