#1 |
At 86 I'm on my 3rd A. Super happy with all of them only question I have is about the tranny, My current '28 the shifter cannot be pulled up and moved out of the way. It is Feb '28 build would that make the diff?
Gene ![]() USN |
#2 |
should work if standard model a transmission!
www.whidbeymodelaclub.com |
#3 |
I thought all shifters moved. Maybe it's just stiff.
#4 |
Find a teenager and have them try it.
#5 |
I'm a bit confused... What exactly is meant by 'pulled up and moved out of the way'?
Thanks |
#6 |
#7 |
Why would you want to swing it away?
#8 |
To move your girl closer. Why would you think. Every young bloke knows that.
I know many things, But I don't know everything, Sometimes I forget things. And there are times when I have a long memory. |
#9 |
#10 |
My father-in-law told me about this feature long before I had a model A. He said they called it a "dating stick."
Marty |
#11 |
First I've heard of this feature, too.
Question....Do you swing away the shift lever while driving, or is this just a feature to be used while parked? eog |
#12 |
Someone please share a video of this
#13 |
I've never seen anything saying this was a 'feature'as such.It's just a design of holding the shift lever that happens to let you pull it up and swing it.Has anybody ever seen any documentation saying this was an intended action from Ford?Years ago somebody tried to do some research on it,and the best he came up with were some dealer ads talking about the feature.But,those were dealer written not from Ford.
#14 |
Back in early high school I had a Fait spider, I rigged the shift lever with a quick disconnect so I could quickly remove it out of the way...for that exact reason...Oh those were the days
#15 |
Thanks, all, for the info. I'll give it a try.....
#16 |
I have heard this story for at least 35 years. I also had a very well-known Model A guy tell me he tried it and the gears slid out of position and he could not re-engage the shifter. He had to call AAA to get the car home. Had to pull the floorboards and the tower to get it working again.
Tom Endy |
#17 |
My dad had a Ford with a column shift,I can't remember what year it was but it had a flathead in it.He drove the roll pin out of the lever and flipped the lever over to the left side,and drove the pin back in.That car jumped out of second unless you held the lever up.With the lever on the opposite side second was down,and the weight of it pretty much let it stay in gear without holding onto it.I remember him telling people it made it easier for him to reach around and slap us kids.
#18 |
The real reason (so I've heard) was so that when parking the car, the driver could get the shifter out of the way and slide over to the other side and exit and enter the car through the passenger door. Apparently that's why the passenger door has the lock on it. People didn't have to use the drive's door in traffic. Personally, I find it hard to do with the Tudor seats. Maybe better with the bench seat.
#19 |
I can't do a video, but can do photos. First photo in normal position. second photo partially swung. third photo all the over to the tank. Pull up on your shifter and just swing it. Swing it back and it should drop right back into your shifter forks, but as Tom says, maybe not. It works on our car, but can't speak for your car.
When i bought my first Model A in the early 1980's, my dad played a trick on me. He pulled the shifter and swing it over when I wasn't looking. I got in the car later and had a WTF moment, then pulled it back and it did reengage and shift OK. We both had a good laugh. So is this an intentional Ford feature? Beats me. And no. Do not try this when your car is running or in motion. Parking only. |
#20 | |
![]() Quote:
Since many of the Model T's didn't have a functioning driver side door, it would make sense that getting out on the passenger side would be a natural manufacturing consideration for the Model A. It may not make much sense nowadays, but, I can imagine it very well could have made perfect sense in 1928! eog
1928 closed cab pickup. All black, no bling or add-on shiny stuff. Just a simple working man's truck. |
