Old 06-03-2022, 10:48 AM   #1
ljaynavl
Default Modern Points & Condenser - Napa Part #'s Please
I have a modern points/condenser plate (Nurex) and wanted to grab a spare set of points and condenser at my local Napa store.
Would someone please share the correct part #s for these?
Thanks!
ljaynavl is offline   Reply With Quote
Old 06-03-2022, 11:24 AM   #2
jrelliott
jrelliott's Avatar
Default Re: Modern Points & Condenser - Napa Part #'s Please
Try this info: from my list. If you would like more info send me an email to [email protected]Electrical Parts.pdf
jrelliott is offline   Reply With Quote
Old 06-03-2022, 11:37 AM   #3
ndnchf
ndnchf's Avatar
Upper tier Standard Product Blue Streak points are available from O'Reilly's and others. These are copper plated, have a different (harder?) rubbing block and a felt wiper to lube the cam. The part number is FD8183V. It is on the right, compared to the cheaper points.
ndnchf is offline   Reply With Quote
Old 06-03-2022, 11:40 AM   #4
ndnchf
ndnchf's Avatar
Installed on a Nurex plate.
Old 06-03-2022, 11:54 AM   #5
ljaynavl
Great. Thanks. Any insight on the correct condenser (6V)?
Old 06-04-2022, 09:16 PM   #6
Jim/GA
Jim/GA's Avatar
I use:
Ignition Points: NAPA Echlin ECH CS755
Ignition Condenser: NAPA Echlin ECH FA82. Carry a spare. Easy to change out if needed.
Ignition condensers are not voltage specific (thankfully). They work the same on a 6 volt or a 12 volt car.
For the NuRex plate, when I go to an auto parts store, I tell them I am looking for points and condenser for a 1973 Ford LTD with the 400 CI V-8 engine. That gives them something to punch into their computer and show you the part options to choose from.
Jim Cannon
Former MAFCA Technical Director
"Spread the Joy! Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 06-03-2022, 12:11 PM   #7
ndnchf
ndnchf's Avatar
The Blue Streak condenser is FD77. But I did have one of these fail, so....
Old 06-03-2022, 03:01 PM   #8
ljaynavl
Great. So an equivalent application might be just as well.
Thanks for the assistance!
Old 06-03-2022, 05:33 PM   #9
nkaminar
nkaminar's Avatar
I have had good luck with the Blue Steak points and condensor. I consider them top quality.
