05-24-2022, 01:02 PM | #1 |
Who makes keyes from the number on the lock
I can’t remember the name of the gentleman that can cut keyes from the number stamped on the lock . Any help is appreciated.
Thank you , Gary MacDonald |
05-24-2022, 01:07 PM | #2 |
Re: Who makes keyes from the number on the lock
member here 32 PHIL made ign key for me from the code no, worked great.
kurt |
05-24-2022, 01:42 PM | #3 |
32phil.
05-24-2022, 03:42 PM | #4 |
Thanks guys !
05-24-2022, 06:21 PM | #5 |
Here’s his info, he cut some for my car from the numbers off my door lock cylinder.
https://www.fordbarn.com/forum/showthread.php?t=46583 |
05-24-2022, 06:38 PM | #6 |
05-24-2022, 08:28 PM | #7 |
Another member who can make keys from the code is FlatheadCoupe.
05-25-2022, 10:15 AM | #8 |
x3, Phil all the way
05-26-2022, 11:20 PM | #9 |
I don't want to take business away from Phil or others.
Have you looked local? Safe and lock guys have all the codes if you dont have a key. Bringing you own blank is suggested. My experience, found one 6 blocks from my house in Fl. Plus always good to know someone does it if someone online isn't around or available. |
