#1 |
What do you use to paint an exhaust manifol?
Thanks Dick |
#2 |
VHT cast grey. I heat the manifold up before spraying. For best results, buy a new manifold an use it.
They really make the engine look nice. |
#3 |
2000 degree stove black. Looks great.
#4 |
I just used the spray paint available from the local auto parts dealer. The manifold paint needs to go though a heat cure cycle. Use your gas fired barbecue. The instructions on the one I used called for heat-cool cycles of increasing temperature.
Don't forget the barbecue sauce.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 04-18-2022 at 10:29 AM. Reason: Added info |
#5 |
I used a spray can product called Cast Blast.
#6 |
#7 |
x3 on the High Temp Cast Blast. Snyder's carries it or you can get it online.
Cure it on the gas grill, not in your house oven... trust me on that.
Dave / Lincoln Nebraska |
#8 |
POR15 high temperature paint is the best and lasts for a long time unlike any aerosol paint imo.
"The more things change, the more they stay the same." |
#9 |
Does them paints work on "been on the engine for years manifolds" or does the manifold need to be bare, rust free metal, like new or sandblasted?
#10 |
I have only used the Cast Blast on manifolds that have been sandblasted and cleaned up.
