04-07-2022, 05:37 PM | #1 |
cracked window 39 coupe
I just discovered the driver's side window in my 39 coupe is cracked. Do I need to use glass setting tape when I replace it? Thickness? Any other comments on the replacement procedure are welcome. Thanks, Ernie
04-07-2022, 06:58 PM | #2 | |
Re: cracked window 39 coupe
Thickness is determined by measuring the width of the channel, subtracting the thickness of the glass and dividing that number in half.
04-07-2022, 07:34 PM | #3 |
Restorations Specialties sells glass setting tape on page 37 of their catalog.
Takes a couple of minutes top download. https://www.restorationspecialties.c...talog_RSSI.pdf |
04-07-2022, 08:54 PM | #4 |
As an aside, I have found Restoration Specialties to be an excellent resource.
04-07-2022, 09:59 PM | #5 |
when replacing the flat glass in our '41, I found the glass from our local auto glass shop a bit thinner than the original
04-08-2022, 05:44 AM | #6 |
04-08-2022, 07:46 AM | #7 |
Exactly! That's why I posted the formula for figuring out the tape thickness.
04-08-2022, 08:36 AM | #8 |
Maybe you should also figure out why the glass cracked and fix that also......or get an extra when you buy the new glass.
04-08-2022, 10:07 AM | #9 |
Is 1939 glass the same thickness as 1940? My 1940 glass is 1/4 in. thick.
If so, here's some info. from HAMB. https://www.jalopyjournal.com/forum/...glass.1201339/ Here's more glass tape info. from Fordbarn. https://www.fordbarn.com/forum/showt...s+setting+tape Last edited by 19Fordy; 04-08-2022 at 10:12 AM. |
04-08-2022, 10:18 AM | #10 |
When I replaced the vent window on my ‘41 I set the glass setting tape in the sun for a few minutes it made it nicer to work with, I thought the job went very easy.
04-08-2022, 01:19 PM | #11 | |
04-08-2022, 04:52 PM | #12 |
Kube: Thanks for that info. about "today's" measurements. I didn't know that.
04-08-2022, 05:55 PM | #13 |
Ran in to this a number of years ago. Side (quarter) glass would not draw up nicely. That's when I measured....
04-08-2022, 07:56 PM | #14 |
Make sure the channel that the glass fits in is straight without any bends. Otherwise you’ll wind up with another cracked glass.
04-08-2022, 10:25 PM | #15 |
04-08-2022, 11:14 PM | #16 |
Here is what I do. I take the old glass and the channel to the glass shop and let them cut and reset the new in the channel. Why worry about doing it yourself?
