Old 03-31-2022, 05:58 PM   #1
34 fordor owner
34 fordor owner's Avatar
Default Mounting dome distributor
I was able to get my dome distributor off my 34 flathead and out no problem without removing anything extra. Now I got the distributor back and can’t get it to line up properly to be able to mount it. I need some tips.
34 fordor owner is offline   Reply With Quote
Old 03-31-2022, 06:03 PM   #2
DavidG
DavidG's Avatar
Default Re: Mounting dome distributor
Turn the rotor of the distributor until the tongue on the back of the distributor lines up with the offset slot in the end of the camshaft in the hole in the timing gear cover.
Old 03-31-2022, 06:32 PM   #3
34 fordor owner
Got it!! And does the vaccum line to the intake have to be connected?
Old 03-31-2022, 06:34 PM   #4
Mart
Mart's Avatar
I will be posting a video tomorrow which shows the distributor slotting into the cam. This may or may not prove helpful.
Offer the distributor squarely and slowly rotate the rotor. If you think it might be trying to engage, try it 180 degrees around from there. In one of the positions it should slot into place cleanly.
Mart.
Edit: No the vacuum does not have to be connected to fit the distributor.
Edit 2: You will need to have either the coil or one of the side plates not fitted to rotate the rotor. I normally only use crab type so rotating the distributor is easier.
Old 03-31-2022, 06:42 PM   #5
MGG
MGG's Avatar
Make two temporary studs and put them in finger tight. This will allow you to slip the gasket on and then the distributor. Turn the rotor with your finger as you line up the slot and slide the distributor in. Install the third bolt and then replace the two studs one at a time with the permanent bolts. Easy-peasy.
MGG is offline   Reply With Quote
Old 03-31-2022, 07:11 PM   #6
34 fordor owner
I got it on and all put back together. Still yet to fire. Trouble shoot, trouble shoot, trouble shoot.
Old 03-31-2022, 08:44 PM   #7
petehoovie
petehoovie's Avatar
If you can, post some pictures of your installation of your distributor...
Old 04-01-2022, 06:38 AM   #8
koates
Test for spark first. Remove one spark plug lead off the plug and hold the end of the lead about 1/4"" away from a head stud nut and have someone crank her over on the starter. If you have a nice spark then look at the fuel system. If you dont have spark then fault find the ignition circuit. Make sure you have the ignition switch ON for your spark test. Regards, Kevin.
koates is offline   Reply With Quote
Old 04-01-2022, 07:52 AM   #9
rockfla
rockfla's Avatar
You did ALSO remember to re-connect the coil power wire? The simplest AND FIRST major check!!! IF so then Kevin's post above is the first go to move!!!!
Old 04-01-2022, 07:49 PM   #10
VeryTangled
VeryTangled's Avatar
And a caution to add to Kevin's comment. After EACH AND EVERY starting attempt, turn off the switch on the column. Do not forget.
Forget this step and you risk purchase of a new coil (when it stays in charge mode as long as the switch is on and the distributor stops with the points closed, if I have that correctly).
Here are a couple of screen grabs from Mart's video that he mentioned above that illustrates the tang/camshaft junction.
Originally Posted by VeryTangled View Post
For future reference to folks.
I was just catching up with Mart and his Pendine Prep series. This one is video #7. Between 21:30 and 23:00 you get an excellent visual description of him fitting a distributor tang into the slot in the end of the camshaft. First pic is the wrong way, second is when the tang dropped into the slot. Later in the video he dresses the tang to get an even better engagement.
Maybe it will help someone else.
Nice job Mart!
the video: https://youtu.be/Ydy38R7EPL8
Mart's thread about the video: https://www.fordbarn.com/forum/showthread.php?t=311700
Mart's YouTube channel: https://www.youtube.com/channel/UCzc...Vro40j-vjjZShg
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 04-01-2022, 08:13 PM   #11
Bill OH
I always take a look at the front of cam to see where the offset is located and I align the distributor the same. Never had any trouble getting the distributor to slid in very easy. Been using that method since 1950.
Bill OH is offline   Reply With Quote
Old 05-24-2022, 05:28 PM   #12
torpedo
torpedo's Avatar
Wink Re: Mounting dome distributor
Hi,
Planning the replacement of the V8 dist.
Could someone provide size for studs (diameter, length) so I can prepare for easier fitting as suggested above ?
Many thanks
Flathead enthusiast - 1933 Phaeton
torpedo is offline   Reply With Quote
Old 05-24-2022, 05:31 PM   #13
Mart
Mart's Avatar
5/16 UNC about an inch long would do it.
Old 05-24-2022, 05:36 PM   #14
cas3
Make sure they are not too long, you can hit the timing gear !
Old 05-24-2022, 06:07 PM   #15
torpedo
torpedo's Avatar
Thanks Mart
Keep the youtube videos going. they're great ;-)
Old 05-30-2022, 05:36 AM   #16
Karl
Karl's Avatar
Originally Posted by torpedo View Post
Hi,
Many thanks
Carburettor studs of an old inlet manifold works fine -Karl
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
