03-28-2022, 10:52 PM | #1 |
Recommended weight oil for 1926 Model T
I just recently acquired a running 1926 Model-T. It appears the engine has not been into, rebuilt or anything like that. Just wondering what might be the best weight of motor oil to use when i change it. I was considering Havoline 30 HD... Comments or thoughts?
03-28-2022, 11:26 PM | #2 |
Re: Recommended weight oil for 1926 Model T
Good choice.
03-31-2022, 05:50 PM | #3 |
Times two. straight weight behaves the best, in this situation.
Enjoy yer day. Tom Hate can't fix what it started. |
04-01-2022, 04:50 PM | #4 |
X's 3 a neighbor happened to have two cases of ND30 he gave me, have enough for oil chages until I retire
If you do not have it already make sure you have a transmission oil screen and also install the outside oil line that is fed off the magneto post. |
04-02-2022, 06:49 AM | #5 |
You should be fine. When I got my all original 27 Coupe last fall I am pretty sure somebody put transformer oil in it, at least that is what it smelled like. Car still runs!
"The more things change, the more they stay the same." |
04-02-2022, 11:21 AM | #6 |
04-04-2022, 04:58 AM | #7 |
I use Mobil 1 from https://casperoilchange.com/syntheti...stroke-diesel/ both for old Ford cars and for my truck, it is great for powerful engines, it has good viscosity and low consumption, it also protects against overheating
04-05-2022, 11:50 AM | #8 |
10-30 or 10-40 depending on the time of year and change often.
