03-28-2022, 07:20 AM | #1 |
Valve guide
What is the best way to remove valve guides,, when you don't have the proper tool?
Thanks Dick |
03-28-2022, 08:10 AM | #2 |
Re: Valve guide
If you have the original style valves with flared base and split guides, my recommendation would be to buy the tool. You could damage the casting around the guides without the proper tool.
If you have the modern style valves, you can remove the valve keepers and slide the valves out, then tap the guides out. |
03-28-2022, 11:50 AM | #3 |
Re: Valve guide
Get the tool that wraps around the valve stem and tap valve with brass hammer. Save yourself lots of time and headache
03-28-2022, 02:23 PM | #4 |
Re: Valve guide
some of those guides are real tight from years of crud oozing into them. some i have had to cut the valve stems off, take the valve out the top, then drive the guides out with a punch.
so i. like the others would suggest buying or borrowing the proper tool. you don't want to damage a seat, guide boss or valve.
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." |
03-28-2022, 03:39 PM | #5 |
Re: Valve guide
Ditto to the comments above. I removed 16 this summer with the correct tool, after 2 or 3 it became an easy procedure.
03-28-2022, 07:35 PM | #6 |
Re: Valve guide
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
03-29-2022, 09:43 PM | #7 |
Re: Valve guide
buy the proper tool, its worth it
