#1 |
I have a newly acquired '28 P/U with a frame that has 4 half cylinder pieces attached. Any idea what these are? They aren't on the frame of my '30 P/U.
#2 |
Those are shocks. Often leak and non-functional... sometimes, but rarely, rebuildable.
#3 |
![]() Ford Model A Shock Absorbers. |
#4 |
This is the time the vacuum finds your wallet. Mine came with only two and I went for the original design replacments.
Regards Bill |
#5 |
They are hydraulic shock absorbers and came on all production Model A's. You may find the addition of them to your pickup will greatly increase the ride.
No one wants advice - only corroboration. -John Steinbeck |
#6 |
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
#7 |
Easiest and cheapest way out for shocks is modern tubular shock conversion.
#8 |
IMO, the suppliers of these conversions should have done a little more work before taking them to market. Tele shockers are way too stiff.
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
#9 |
First, disconnect the links. Looks like one is already disconnected. Try to move it up and down. Move the arm to the one that does not have one to test that one. If it moves but easily, try adding some shock oil, available from the vendors, at the square plug at the top. It if has resistance with new shock oil, congratulations, you just saved a ton of money. If not, or if frozen solid, send them in to have them rebuilt.
They are really hard to rebuilt without special tools. If the springs are dry and stiff the car will work without shocks but the springs should be rebuilt with dry lubrication or grease and shocks added. Because they are hard to rebuild and parts were not available for a long time and because most of the shocks were worn out, lots of cars had them removed back in the day.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 03-22-2022 at 07:54 PM. |
#10 |
Just had a thread about this...that's why a lot, and I mean a lot a A's had no shocks or they were disconnected.
Modern shocks work great (and much cheaper) if you are into driving and not high point showing
#11 |
Thank you for the help identifying them. I am definitely going to clean/dust them off and see if they are totally shot. If they aren't totally gone, I will see about getting them rebuilt.
#12 |
