Old 03-19-2022, 12:50 PM   #1
Lawson Cox
Lawson Cox's Avatar
Default Cutting into gas line. Consequences.
I'm embarrassed for publicly asking this question but memory is unclear nowadays. If I cut into fuel line to swap out fittings at electric fuel pump which is mounted inside the frame rail close to the tank, the only gas that will drain out is the gas in the line, correct? No siphoning action of gas out of the tank, Correct? I can't believe I'm asking this question.
Old 03-19-2022, 01:08 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Cutting into gas line. Consequences.
I don't know how things are plumbed in your case. Maybe it wold be a good idea to keep a pan handy just in case.
Old 03-19-2022, 01:11 PM   #3
Lawson Cox
Lawson Cox's Avatar
Always.
Old 03-19-2022, 01:52 PM   #4
Brian
Brian's Avatar
If, where you cut, is lower than the level in the tank, it certainly will syphon. Why not drain the tank? be less mess and safer.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 03-19-2022, 02:44 PM   #5
51 MERC-CT
51 MERC-CT's Avatar
Just crack open a fitting with a pan at the ready, if no continual flow after lines have drained, you're good to go.
Old 03-19-2022, 03:18 PM   #6
Ronnieroadster
Ronnieroadster's Avatar
Any early Ford fuel line I worked where the gas tank was located at the rear under the car once the fuel line along the frame rail was opened up gas began flowing.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Ronnieroadster is offline   Reply With Quote
Old 03-19-2022, 05:26 PM   #7
19Fordy
19Fordy's Avatar
Lawson, While you're at it, install a petcock in the fuel line between the tank and your in line filter and fuel pump. I used a radiator pet cock you see in photo. Fuel line is 1/4 in.
Old 03-19-2022, 05:50 PM   #8
Lawson Cox
Lawson Cox's Avatar
Thanks for reminding me to drain the tank, Brian. I was planning on doing that anyhow and blowing out all of the gas lines. I will also be replacing the rubber hose that is connecting the gas line and electric pump. I am getting crud in the carburetor from somewhere, two in line filters between the tank and carburetor notwithstanding. Frustrating.
Old 03-19-2022, 06:02 PM   #9
Ford Freak
Hey Lawson! When you replace the rubber hose, make sure it is labeled "fuel injection".
It will hold up better with today's gas, that has ethanol in it. Around my parts it is 10%.
- Bernie
1952 Ford F1
!956 Fairlane Club Sedan
1965 Falcon Sprint
2007 Mustang GT
Ford Freak is offline   Reply With Quote
Old 03-19-2022, 08:05 PM   #10
Lawson Cox
Lawson Cox's Avatar
Hey Lawson! When you replace the rubber hose, make sure it is labeled "fuel injection". It will hold up better with today's gas, that has ethanol in it. Around my parts it is 10%.
- Bernie
Gotcha. Already have the hose in my hot little hands.
Old 03-20-2022, 09:06 PM   #11
Karl
Karl's Avatar
- Bernie
I have always been reluctant to use ethanol gas as I'm afraid of what it will do to rubber parts - What precautions do others take (if any ) when using ethanol gas ?
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 03-20-2022, 09:53 PM   #12
GB SISSON
GB SISSON's Avatar
Lawson, if you have any rubber hoses upstream of where you are working, this is what I do. Clamp the hose off with a set of small needle nose vice grips. I slide an inch or so of rubber fuel line on each jaw of the vise grips to protect the hose. I have been beside the road changing filters with fuel running down into my armpits way too many times. I refuse to drive any more with a tank that is even remotely questionable. My current stable has 2 poly tanks, one aluminum and one solid original heavily treated with red-cote.
Old 03-21-2022, 01:03 AM   #13
T Scott
My guess is that if your pump is lower than the fuel level in the tank then yes, it will siphon. My 37 Lasalle had a similar configuration and at 82 I will do almost anything these days to avoid climbing under a car, particularly to change a fuel filter with fuel running down my arms. I installed two Facet pumps in series with a downstream filter on the frame rail in the engine bay with a selector switch for the desired pump. Having two pumps is for redundancy. These pumps will lift fuel from the tank just like the original 84 year old pump did and changing the filter is a piece of cake. Worth considering.
T Scott is offline   Reply With Quote
Old 03-21-2022, 06:08 AM   #14
CA Victoria
CA Victoria's Avatar
Sill getting crud in the carb w/2 filters?
Shouldn’t be passing thru your filter-
Start with what is between filter & carb and carb itself-
Are you using fords flex line at the fire wall?
Rubber line collapsing?
Has your carb been updated with alcohol friendly pump?
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
