Old 03-19-2022, 09:10 AM   #1
AnthonyG
AnthonyG's Avatar
Default Water pump install question
What to use on pump to engine interface grease on gaskets or RTV?
Nomad
AnthonyG is online now   Reply With Quote
Old 03-19-2022, 09:30 AM   #2
Bored&Stroked
Bored&Stroked's Avatar
Default Re: Water pump install question
I use 'GasgaCinch' on many gaskets - it is a very thin sealer that comes in a can with an applicator in the top. I have used it for 40+ years on things like water pump surfaces, intake manifolds, etc..
RTV works fine as well (for waterpump gaskets), just don't buy the "blue kind" - looks like Hell no matter how much you wipe off!
Link: https://www.jegs.com/i/SCE-Gaskets/829/G1614/10002/-1
I use RTV on the oil pan and the ends of the rear/front main rope seals. Depending on the head gasket material, I usually use spray on 'CopperCoat' on them. One some applications I use Hylomar for the head gaskets (solid copper head gaskets).
Gasket sealers are one of the subjects where you'll get many opinions - and many different products and processes that ALL work . . . just pick your poison!
Old 03-20-2022, 10:38 AM   #3
19Fordy
19Fordy's Avatar
On my 8BA water pumps I use a thin coating of PERMATEX Non-Hardening gasket sealer.
Be sure to read this thread about NOT using RTV and silicone
https://www.fordbarn.com/forum/showthread.php?t=311227
Old 03-20-2022, 11:45 AM   #4
DavidG
DavidG's Avatar
Me too (Permatex).
Old 03-20-2022, 12:47 PM   #5
Lawson Cox
Lawson Cox's Avatar
Grease
Old 03-20-2022, 03:03 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
Anthony....Not to change the subject, but did you ever get your spindles/brakes project completed? I don't remember seeing any resolution on that. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 03-20-2022, 04:41 PM   #7
deuce_roadster
deuce_roadster's Avatar
The one time I used grease, it leaked. Always use Permatex or like product which never leaks.
Old 03-20-2022, 07:00 PM   #8
aussie merc
aussie merc's Avatar
another vote for non hardening gasket cement [permatex] defiantly not rtv of any kind
aussie merc is offline   Reply With Quote
Old 03-20-2022, 07:08 PM   #9
Lawson Cox
Lawson Cox's Avatar
Tighten it tighter. lol
Old 03-20-2022, 07:47 PM   #10
paul2748
paul2748's Avatar
Never had a problem with RTV - you have to use a very thin coating
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-21-2022, 03:39 AM   #11
Karl
Karl's Avatar
I use grease never had a leak (yet!)
Rolls Royce use Hylomar Blue on their engines I think -they don't leak much either
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 03-21-2022, 10:10 AM   #12
AnthonyG
AnthonyG's Avatar
DD, New info on juice brake project. While I did get the spindles reamed & KP’s fit well, I was planning on doing work in a metal pole building a friend is having built because my garage is pretty tight. But with builders being crazy busy it got postponed til April / May which puts us into May /June for a start. As I did quite a bit of engine refresh last season & don’t want to lose another season I think I’ll have some fun with it this season as is with the mechanicals which work as they’re supposed to & do the juice brake project in late fall later this year. I’ll definitely post progress when I start.
Nomad
Old 03-21-2022, 10:14 AM   #13
AnthonyG
AnthonyG's Avatar
Thx guys, I was leaning towards grease. It must have been assembled last build with grease, came off very easy & can barely see any residue barely had to clean & never leaked. Just putting hi-flow unit in.
Thx
Nomad
Old 03-22-2022, 05:26 PM   #14
uncle max
uncle max's Avatar
Hylomar was developed by the RAF to stop leaks on Rolls Royce-Merlin engined Spitfires. You could say it helped win the war.
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 03-22-2022, 09:02 PM   #15
Bored&Stroked
Part of the reason that Hylomar is such a good sealer is that it never truly sets up - it remains elastic, and fuel does not touch it . . . so it is good for many things. I have it in cans with applicators as well as spray-on. I use the spray on for blown applications with 0-ringed heads.decks and solid copper gaskets - works really well. But - it is not cheap!
Old 03-22-2022, 09:11 PM   #16
Pete
The words "good" and "cheap" seldom go together....
Old 03-23-2022, 12:09 AM   #17
bobH
thin layer of 'Right-Stuff'.... another one that is 'not cheap'
bobH is offline   Reply With Quote
Old 03-24-2022, 07:56 AM   #18
Bored&Stroked
Yep, but some folks keep thinking that cheap is "always good" . . . then they find out the hard way! LOL
Old 03-24-2022, 09:51 AM   #19
39fordtruck
What colour Hylomar?
39fordtruck is offline   Reply With Quote
Old 03-24-2022, 07:37 PM   #20
Bored&Stroked
The only color I've seen was blue . . . but I've not looking to see if there were others.
