03-16-2022, 03:14 PM | #1 |
The GREAT Ms. American 3.14159's Left Brake Light Won't Light Mystery Caper
Hey all,
Have something mysterious going on with Ms. American's Left Brake Light. When the Headlights are on, both Tail Lights come on. When the Turn Signals are activated, both Tail Lights come on (separately, of course). But when the Brake Pedal is activated, only the Right Brake Light comes on! The Right Brake Light is at the end of the circuit, so the circuit has electricity. Also, the Left Turn Signal shares the same filament with the Left Brake Light, and as mentioned above, the Left Rear Turn Signal works. Don't know why the Left Brake Light won't light. Any suggestions? Hope this finds you all doing well, and staying safe. JC Allison
Ms. American 3.14159,1964 Ford Galaxie 500,Model:64 4-Door Hardtop,Body:57B 4-Door Fastback,Police Interceptor,390 CID,330 HP,P-Code FE,Solid Lifters,Cast Iron Shorty Headers,Autolite 4100 C4AF-9510-DG Carb,Mustangs Etc.Manual Choke,3 Speed BorgWarner T85 Overdrive Transmission,4.11:1 Differential,Kelsey Hayes Severe Service Wheels,PerTronix Ignitor III HEI,60,000 Volt PerTronix FlameThrower HC Coil,Frantz Oil Cleaner,Chantilly Beige |
03-16-2022, 03:37 PM | #2 |
Re: The GREAT Ms. American 3.14159's Left Brake Light Won't Light Mystery Caper
I would think it has to be something with-in the turn signal switch causing it.
Have someone look at the brake lights, and see if the left one comes on and stays on if you just wiggle the blinker lever ever so slightly. .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN What I GOT DONE TODAY... I put my rear-end in the recliner, and now I'm going to rest up & watch TV. |
03-16-2022, 05:03 PM | #3 |
03-17-2022, 07:31 AM | #4 |
Swap bulbs and see if it stays the same. Easy to do and rule out a bulb issue.
03-17-2022, 09:13 AM | #5 |
If you have the taillights on and then apply the brakes, does the left taillight stay on or go off? If the taillight also goes off indicates an issue with the ground connection for that lamp.
03-17-2022, 01:18 PM | #6 |
03-18-2022, 12:02 AM | #7 | |||
GOOD, as long as the tail-lights are the "low" brightness filament.
If the bulb and socket are not at fault, look at the wiring connector ahead of the bulb and identify the "high" brightness wire. Unplug it and inspect connectors for corrosion. Clean and coat with silicone grease and reconnect and test again. |
03-18-2022, 12:10 AM | #8 |
There may be an issue at the wiring junction-block under the dashboard immediately downstream of the turn-signal wiring harness. Notice how the two wires from the controls (brake-light switch and turn-signal switch) come back out the other end as ONE wire which goes to the back of the car for the lights?
If you know your cars wiring color-code, identify the incoming wire into the junction block from the brake light switch and disconnect/clean and plug back in. The one wire going out of the switch to the back of the car should be good since we know that at least one of the "high" brightness elements is working. |
03-18-2022, 05:51 PM | #9 |
It is the switch I would bet. The switch makes or breaks the contacts and circuit. Lot of things going on in the switch and none of them have anything to do with parking lamps, they are on separate circuit. 2 power wires enter the switch, one of them is power when brakes are applied with full time power and other is ignition/accessory power through signal flasher. What direction the signal lever is turned to the switch turns off the brake lamp to that side and is powered by the flasher/ignition circuit wire. It also separates the front turn signals dashboard indicators from the rear so front turns don't illuminate during braking. Your only intermittent repeatable illumination failure points to the signal switch. NOS seems to be quite expensive and the fishing of wires through the column can be a task. It may be disassembled cleaned and reassembled with adjustments made to contacts. You may need to find the ever elusive star lock push on lock washer.
03-18-2022, 06:16 PM | #10 | ||
There has appeared another anomaly regarding the Brake Lights: The Right Brake Light doesn't always go off when the car is parked after using the Brakes to stop the car in its Car Port. Just have to jiggle the Brake Pedal to get it to go off. Anyway, thanks for taking the time to respond. Take care. JC
03-18-2022, 06:20 PM | #11 | |
Have for the past three days been dealing with a semi-serious health issue, and haven't had much time to respond, but am determined to catch up on the sage advice from everyone. Stay tuned! JC
03-18-2022, 06:28 PM | #12 | |
Anyway, take care, and stay safe. JC
03-18-2022, 06:46 PM | #13 | ||
Take care. JC
03-18-2022, 06:50 PM | #14 |
Hey Mr. E, it certainly seems to be a problem that comes with aging. Ms. American will be 58 years old on Sunday. We all seem to wear out sooner or later.
Will run the test on the Turn Signal Switch, and see how it comes out. Stay tuned. JC
03-18-2022, 07:04 PM | #15 | ||||||
Stay safe. JC
03-18-2022, 07:15 PM | #16 | ||||
Will find out in the morning. It may even take putting in NEW Bulbs to keep both sides the same brightness. Will keep you all updated if, when, and as progress occurs. JC
03-18-2022, 07:22 PM | #17 | |
So with all the places to look that have been suggested, tomorrow should be a very busy day. Will keep you all updated if, when, and as progress occurs. Stay safe everyone. JC
03-18-2022, 10:12 PM | #18 |
If it hasnt already been mentioned, just swap bulb for bulb and observe if the same problem switches position. Just a thought. Jim
03-21-2022, 09:53 AM | #19 | |
Am suspecting that Ms. American has been pulling into the Car Port with the Left Turn Signal ON, and it has not been turned off when parked. So it appears that this whole thing was a "false alarm", because everything is working EXACTLY as it should work. Am relieved to know that everything is as it should be. Want to thank everyone for their sage input. Anyway, hope this finds you all doing well. Take care. Stay safe. JC
03-21-2022, 11:30 AM | #20 | |
