Old 03-14-2022, 05:56 PM   #1
mcgarrett
Default 1940 Ford wheels?
I have two 6.00 x 16" Ford wheels with dates of 11-18-40 and 11-19-40 stamped on the wheels. Would I be correct in assuming by the dates being so late in the year that they would be for use on 1941 Fords?
mcgarrett is offline   Reply With Quote
Old 03-14-2022, 06:17 PM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: 1940 Ford wheels?
Production of 1940 Ford passenger cars was for pretty much ceased by October, 1940.
So yes, you'd be correct in assuming your rims would have been installed on a '41 Ford.
Other than the date codes, the rim design is the identical to 1940.
Old 03-14-2022, 06:23 PM   #3
mcgarrett
I was pretty sure that was the case and it makes sense.
Old 04-07-2022, 02:42 PM   #4
alchemy
alchemy's Avatar
6" wide 1940 wheels? Are you sure? If they really are, they have to be rare commercial wheels, and are probably very valuable.
alchemy is offline   Reply With Quote
Old 04-07-2022, 03:03 PM   #5
Kube
Super Moderator
Kube's Avatar
My guess? The original poster was measuring the very outside width.
Old 04-07-2022, 03:14 PM   #6
svm99
If not a typo, then agreed, we should school them, wheels are measured inside the flange. The wheel will be stamped with the size near the date stamp also.
Paul J.
svm99 is offline   Reply With Quote
Old 04-07-2022, 03:38 PM   #7
cas3
Tire size 6.00 x 16 is my guess
Old 04-07-2022, 07:00 PM   #8
Kube
Super Moderator
Kube's Avatar
A good and reasonable guess for certain.
I'm going with my theory still. The poster did state "wheel"- not tire.
Still, anyone's guess...
Old 04-07-2022, 08:12 PM   #9
alchemy
alchemy's Avatar
Sorry, I just got excited. The wider steel wheels of the era are very coveted, and some with 1940 dates sounded like a real oddity.
Old 04-08-2022, 07:18 PM   #10
mcgarrett
The wheels I was referring to in my original post are designed to fit tire size 6.00x16.
Old 04-08-2022, 07:51 PM   #11
mercman from oz
mercman from oz's Avatar
1940 Ford Deluxe 16 Inch Wheel
Old 04-08-2022, 11:00 PM   #12
V8COOPMAN
V8COOPMAN's Avatar
Ain't that pretty? It just so happens that that particular wheel/tire is the original spare out of a '41, although it is the same wheel as a '40. Note the "FORD" script on tire at about one o'clock! Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 04-08-2022, 11:58 PM   #13
cas3
I have a ford script tire, well not mint like that one, but it is ford script !
Old 04-09-2022, 12:17 AM   #14
Lanny
Lanny's Avatar
Note how the lugnut hole on the '40 and the '41 wheels have the normal
taper on the inside of each lugnut hole, but the '40 & '41 Wheels do NOT
volcano-out around each lug hole, as my picture of a '46 wheel below is,
but instead the '40 & '41 wheels are FLAT around each lugnut hole.
Click on picture to Enlarge
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 04-09-2022, 12:29 AM   #15
mercman from oz
1946 Ford Wheel Centre showing taper of Wheel Stud Holes - different from the 1940-1941 Ford Wheels. Lanny
Old 04-09-2022, 08:32 AM   #16
Kube
Super Moderator
Kube's Avatar
Good guess! Winner, winner, chicken dinner!
Old 04-09-2022, 08:45 PM   #17
cas3
I got lucky ! ...once
Old 04-10-2022, 10:01 AM   #18
alchemy
alchemy's Avatar
Since we are discussing "original" 40 wheels, I think this is a good place to ask the expert about the changes in 41. The way I understood it was the 40 wheel was 4" wide, with the drop center having square sides on front and back. But in 41 they were 4" with a square drop on the front and a taper on the back. What say you Kube?
Old 04-10-2022, 10:24 AM   #19
V8COOPMAN
V8COOPMAN's Avatar
alchemy ....Do you actually have a 4-INCH wheel with drop center square in front, and tapered in rear? I have never seen a 16" (4" wide) Ford wheel like that. Coop
T5 W/TORQUE TUBE
Old 04-10-2022, 10:33 AM   #20
cas3
Tapered on one side are 4.5" wide I always thought. I had not ever noticed the different stamping around the stud holes though, so I have learned something new here
