#1 |
Can I lower the front and rear a bit by suspension and leave everything else as stock. Alter springs ? ??? Thanks
#2 |
How far are you looking to go?
#3 |
I'd like to go like 3" give or take Txs
#4 |
![]() ![]() This is a 3 inch drop and still looks stock. 1932-1936 axle with a Posies 2 inch drop spring. Posies can also supply a spring to drop the rear.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? ![]() Last edited by Chris Haynes; 03-17-2022 at 09:31 PM. |
#5 | |
![]() Quote:
All I get when I click on the picture is advertising wanting me to open an account. NO WAY!
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
#6 |
#7 |
Just rightclick and open the picture (not the link) in a new tab/window.
#8 |
Go to the HAMB and search the Monthly Banger Meet you will find lots of info
#9 |
Back in the day we would "torch the springs" to lower a car. The springs were heated with a acetylene torch until they bent. To raise a car we would reverse the shackles, which would not work on a Model A.
#10 |
Reverse the spring eyes and remove leaves. This will lower the car a bit but removing leaves reduces spring capability. Reversing the eyes is the least invasive way to alter the height. Dropping the front axle and stepping the rear frame rails in front of the cross member is the old traditional way but the car will be altered a good bit doing that.
#11 |
#12 |
Don't click on the picture. Simply look at it.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? ![]() |
#13 |
Kohler Kustoms, Andy will lower the front and Old Yankee Speed Co makes lowering springs for rear
#14 |
Reverse-eye main leaves will get you two-inches in drop, Posies offers a "low reversed-eye" that will get you another inch. Model T rear spring will result in similar drop. If you want more, you can pull leaves out of the pack, just be sure to not pull a bunch of consecutive leaves as each leaf serves to spread the load. In other words, you want the "span" between the ends of each leaf to be as close as possible.
For example, if you pull the second and third leaf, the distance between the end of the fourth leaf and the spring perch of the main leaf is beyond the design of the spring pack and can put additional stress on the main, since each leaf provides support to the pack. Hope that makes sense. |
#15 |
Why not hop it up too?
#16 |
#17 |
Is this the look you want?
#18 |
#19 |
There’s a whole lot of folks who hop up ford flathead four engines from 28-34.. not too many put the saw their cars. But if they do, it’s their car,I defended their right to do as they wish with their private property and continue to back that freedom. If you want to stop someone from cutting up their private property I suggest buying it from them.
#20 |
No frame mods
Model T Rev eye in rear 9 leaf ,750 x 16 Front 4” drop rev eye 9 leaf , 600 x 16
"I can't cry as long as I know the Lord has risen " |
