Old 03-09-2022, 04:47 PM   #1
Neil Mylar LakewoodCA
Neil Mylar LakewoodCA's Avatar
Default Need help removing gear shift knob without damaging it.
I'm trying to remove an original gear shift knob from my gear shift, but it is stuck.
I've tried PB Blaster to loosen it, but it is still stuck.
I've been using an old towel and have been trying to loosen it by hand.
I don't want to use vice grips for fear of damaging the surface of the knob.
I would appreciate any suggestions.
Thanks in advance,
Neil
Neil Mylar LakewoodCA is offline   Reply With Quote
Old 03-09-2022, 04:54 PM   #2
jw hash
jw hash's Avatar
Default Re: Need help removing gear shift knob without damaging it.
if you don`t care about the nickel on the shifter. take a torch and heat the shifter about 1" down from the knob and let it cool, sometimes it takes a couple times, you want the heat to work it way down into the knob,
jw hash is offline   Reply With Quote
Old 03-09-2022, 04:59 PM   #3
dennis lumbert
dennis lumbert's Avatar
What if you used a strap wrench to try and rotate the knob.They make them with a leather or vinyl covered strap and that should not damage the knob.
dennis lumbert is offline   Reply With Quote
Old 03-09-2022, 05:38 PM   #4
Big hammer
Go to the kitchen and get one of the grippy things you wife uses to open jars or tell a teenager he can’t remove it by hand
get a bigger hammer tap done
Old 03-09-2022, 06:21 PM   #5
Redbird
Redbird's Avatar
Bighammer, I was just going to type in the same thing. Use channel locks over it to not scratch anything.
Redbird is offline   Reply With Quote
Old 03-09-2022, 09:45 PM   #6
Big hammer
With arthritic hands, thinking outside of the box helps, sometimes
Old 03-09-2022, 10:03 PM   #7
Pete
Believe it or not it is possible to have a knob stuck so hard that no matter what you do, you will twist the end of the shift stick off or disintegrate the ball before it comes off.
I had one like this on a customer car once.
We used a strap wrench. It was absolutely not slipping or marking the ball but the ball was not moving so the owner said go for it and see what happens. The end of the stick twisted off. We drilled the piece out of the ball, re-cut the thread on the stick and sent him on his way.
By the way we had the stick on the bench and clamped in a gunsmith type barrel clamp.
Old 03-09-2022, 11:30 PM   #8
Thank you all for your suggestions. I chuckled and appreciated the good humor suggestions, as well.
I did remove it tonight. I first wrapped the knob with a velcro strap and then tried turning it with a huge pipe wrench. That did not work. The velcro did not seem to grip the knob.
Next, I wrapped the knob with velcro again and placed it in a vice. I then turned the shift mechanism by hand and it came free.
The knob is scratch free.
Thanks again,
Neil
Old 03-10-2022, 11:17 AM   #9
katy
katy's Avatar
First time I've heard of using velcro for an anti-slip "gripper".
Old 03-10-2022, 01:08 PM   #10
Fullraceflathead
Fullraceflathead's Avatar
I use an old thick leather belt for things like that
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 03-10-2022, 08:10 PM   #11
McMimmcs
McMimmcs's Avatar
[QUOTE=Big hammer;2111613]Go to the kitchen and get one of the grippy things you wife uses to open jars or tell a teenager he can’t remove it by hand
This was my favourite. Tell a teenager he can’t possibly remove it. His hands will hurt and his face will be red !
McMimmcs is offline   Reply With Quote
