Old 03-07-2022, 11:19 AM   #1
sprint29
Default 36 pickup inner fender well drawings
Good morning.
I was wondering where a guy can get the drawings for the front inner fender wells on a 36 pickup?
Mine are butchered up some and I'd like to see what they are suppose to look like.
Thanks
Mark
sprint29 is offline   Reply With Quote
Old 03-07-2022, 11:22 AM   #2
CA Victoria
CA Victoria's Avatar
Default Re: 36 pickup inner fender well drawings
Check here on page 3 post #45
https://www.fordbarn.com/forum/showthread.php?t=298830
Sorry, I mis read your post.
Rather than make your own, (the top edge is a bit complex) look for a set off of a 1 1/2t truck. You will need to fuss with the bottoms a bit but the tops are spot on. A paper pattern can be used to determine the cut edge on the bottom
Tim
Downtown, Ca
CA Victoria is online now   Reply With Quote
Old 03-07-2022, 03:05 PM   #3
sprint29
The top edge on these things is in good shape. They cut parts of the bottom half to make room for after market shocks. Do you know if both sides are the same except for a right and left?
Old 03-07-2022, 04:53 PM   #4
VeryTangled
VeryTangled's Avatar
Originally Posted by sprint29 View Post
I was wondering where a guy can get the drawings for the front inner fender wells on a 36 pickup? Thanks Mark
Hi Everyone. Mark, if they are anywhere, the drawings are at the Benson Ford Research Center at The Henry Ford in Dearborn. This place has an amazing collection and 'librarians' that know how to find things.
The link, if you go down about 1/2 way, has a Services area. In there is a place where you can ask a research center expert, and another place where you can get fee-based remote research.
Maybe this helps.
https://www.thehenryford.org/collections-and-research/
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 03-07-2022, 07:23 PM   #5
CA Victoria
These aren’t the best but you are correct about being the same shape for R & L.
Send a PM If you need a tracing.
File Type: jpg FFFB3EA0-2574-40E4-90E7-7F3077AE1968.jpg (92.4 KB, 33 views)
Tim
Downtown, Ca
Old 03-08-2022, 01:01 AM   #6
Don Rogers
Don Rogers's Avatar
Here are some pictures of inner fender panels that might help.
Don Rogers is offline   Reply With Quote
Old 03-08-2022, 09:46 AM   #7
sprint29
Thanks guys,
All the info and pictures help greatly. I can fix mine with a little sheet metal work. Just wasn't sure exactly what they looked like. When I got this truck it had an old Doge hemi in it. They had to cut the chassis, firewall, floorboard and fender wells to get this thing to fit. I'm trying to get it back to original.
Old 03-08-2022, 10:47 AM   #8
CA Victoria
Congrats, good to see another one saved
File Type: jpg 21E51639-DE8D-4FE7-AA98-33E81A2C2B1B.jpg (66.2 KB, 11 views)
Tim
Downtown, Ca
