Old 02-21-2022, 04:21 PM   #1
art ebeling
art ebeling's Avatar
Default 1936 pickup gauges
Who do you recommend for new original looking or to rebuild original guages for a 36 pickup? Thanks, Art
art ebeling is offline   Reply With Quote
Old 02-23-2022, 07:56 AM   #2
art ebeling
Default Re: 1936 pickup gauges
Any suggestions? Art
Old 02-23-2022, 08:14 AM   #3
nelsb01
nelsb01's Avatar
There used to be lots of gauges available. The problem with those that are for commercial vehicles is that they are not available in any numbers. I have found that Ford never re-designed anything that it didn't need to, so your 1936 commercial gauges are very similar to the gauges in 1935 Ford passenger cars. Try searching for those.
My suggestion.
As for repairs, I have no suggestions at this time.
nelsb01 is offline   Reply With Quote
Old 02-23-2022, 08:33 AM   #4
FortyNiner
FortyNiner's Avatar
I haven't used this outfit.
https://antiqueinstrument.com/
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 02-23-2022, 09:30 AM   #5
51504bat
51504bat's Avatar
Williamson's
https://williamsons.com/
2018 East Front Ave, Chester, Arkansas 72934
(479) 369-2551
They converted the clock in my '54 Ranch Wagon to 12 volts. Spoke with the owner several times about the conversion and other 6 to 12 volt issues as well. Quality product. Fair price - better than other vendors I contacted.. Took a couple of months IIRC. Previously I contacted them about the temp gauge for my '39 p/u. A PO had cut the bulb off the capillary tube. The quoted price at the time was fair but I ended up just using 2 VDO gauges hung under the dash.
Old 02-23-2022, 09:39 AM   #6
uncle buck
uncle buck's Avatar
I second 51504bat's suggestion of Williamson's for rebuilding or modifying original gauges.
uncle buck is offline   Reply With Quote
Old 02-23-2022, 09:58 AM   #7
OldGold360
They look like they do good work.
OldGold360 is offline   Reply With Quote
Old 02-23-2022, 10:27 AM   #8
oldandtired
I believe the 36 pickup used the same gauges as the 36 passenger car. 36 pickups came in a Standard and in a Deluxe. Some of the pickups would have had two single gauges and some would have had two double gauges. Some of the gauges are still available NOS. You probably would not want to use a 35 gauge setup even though they would fit the 36 dash because the 35 has a hydrostatic fuel gage and the 36 has an electric. It would help to know if your pickup has the two single gauge setup or the two dual gauge setup.
oldandtired is offline   Reply With Quote
Old 02-23-2022, 04:46 PM   #9
art ebeling
My pickup has the two dual guage setup although it is missing the amp out of one and the oil out of the other. I just made a deal for a complete working set except the odometer doesn't work for 250.00. I think that is a good deal. Art
Old 02-24-2022, 06:53 AM   #10
oldandtired
Good luck to you with your 36.
Old 02-24-2022, 10:13 AM   #11
art ebeling
Thanks, I am finding out that parts are hard to find compared to the Model A's and T's I have done. Art
Old 02-24-2022, 12:19 PM   #12
OldGold360
Yes, I discovered the same thing. This being the main reason I began making parts for these pickups.
