#1 |
I thought I would use my 8BA in the 36 until I get my 59ab engine built.
Never gave any thought to the oil pan. I guess this must be a car oil pan and I need a truck pan. I got lucky and have one in my scrap block pile complete with a pickup. I am also wondering what the wide long seal is for on the rear of the truck pan. I’m using a 37 steering arm instead of the 36 arm. It seems the 37 arm curves upward and with would lift the drag link higher. Thanks |
#2 |
Does that look like the right oil pan to use? Will I probably have to modify the front to clear?
#3 |
I wouldn't do it. I put a '50 Merc engine in my '36 a long time ago. I used the Merc water pumps (they are very similar to truck pumps). The engine sat too low, so I modified the front of the pan. Later on I found out that truck pumps make the engine sit higher, so the pan doesn't need to be modified. There are spacers available for use with the Merc pumps that raise the engine, but I was not aware of them back then.
#4 | |
![]() Quote:
Here are two different examples of the U-shaped spacers that "tubman" is talking about. The second example has holes directly above one another, whereas the first example has holes that are offset, so as to accommodate for a chassis mount that is slightly wider. DD . |
#5 |
I have what thought are truck pumps.
Can I safely lift the front of the engine 1-1/2 to 2 inches and not interfere with the angle of the drivetrain or any clearence issues. I have no weight sitting on the mounts in the pictures. Thanks |
#6 |
#7 |
#8 | |
![]() Quote:
I’ll look at everything a little closer tomorrow. Then I can drill holes in the tubing. |
#9 |
I have an 8BA in my '36 with truck water pumps. And the oil pan has a large, like 8 or 10 inch hole in it. The pan fits great.
Steve in Denver |
#10 |
That’s the oil pan that I didn’t use. I have one I grabbed off my scrap block pile. The one in the frame is a car pan with the hump in the middle. Raising it a 1-1/2” seems to clear everything.
#11 | |
![]() Quote:
Bill |
#12 | |
![]() Quote:
#13 | |
![]() Quote:
Bill |
#14 |
I cleaned up the truck pan that I had and put that on. I’m happier with the clearance and no spacers need.
#15 | |
![]() Quote:
Bill .....You're probably correct, and I'm wrong with my long-winded B/S above. I thought that he was talking about the TRUCK pan with the BIG clean-out, and NOT that pan that he ran the drag link UNDER with the flat bottom. SORRY! DD . |
#16 |
In a perfect world, the front end of the crank would still line up with the original hand crank hole whether or not you plan to use it. That plan also keeps proper clearance at the back for fuel pump stand etc.
