Old 02-14-2022, 11:23 PM   #1
DNLs1930
DNLs1930's Avatar
Default 16in wheel tires
Have a question for those of you who have 16in 1935+ ford wire wheels installed on your car.
What size tire are you running?
Same size front and back?
Same width front and back?
And finally I understand they (tires) are tubeless modern radials; is this a good guess or are you also running tubes?
Thanks in advanced!!
PICTURES are always welcome!!!
Looking to have a slight "rake" for a mild "hotrod" look which I think my uncle was trying to accomplish when he had the car. (car has been in our family since 1935) so not wanting to totally hotrod it just get a part of the look.
DNLs1930 is offline   Reply With Quote
Old 02-14-2022, 11:47 PM   #2
PC/SR
Default Re: 16in wheel tires
Try 600x16 front, 650 or higher in the back.
PC/SR is offline   Reply With Quote
Old 02-15-2022, 02:49 AM   #3
Model A Ron
Model A Ron's Avatar
I would keep the original Model A wheels......the 16's make it look more like a hotrod in my opinion.
Model A Ron is offline   Reply With Quote
Old 02-15-2022, 08:17 AM   #4
1929
215x85 front and rear tubeless.
1929 is offline   Reply With Quote
Old 02-15-2022, 07:02 PM   #5
tinkirk
tinkirk's Avatar
These are radials back are 235R85/16 not positive on the front I will need to look at them to know for sure
tinkirk is offline   Reply With Quote
Old 02-15-2022, 07:15 PM   #6
MAG
MAG's Avatar
Agree with post 3.
I think a better place to post this is on the Hot Rods and Customs Forum.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 02-15-2022, 07:26 PM   #7
McMimmcs
McMimmcs's Avatar
Originally Posted by MAG View Post
Agree with post 3.
I agree with you. Obviously it doesn’t look like a Model A anymore.
McMimmcs is offline   Reply With Quote
Old 02-15-2022, 07:40 PM   #8
DNLs1930
DNLs1930's Avatar
Ok so you all know; I do have the original 19in wheels I plan to keep and use for those times that 1930s Model A specific look in desired.
I also have my family car that had the wheels in the picture installed so not sure where to draw the line.
My uncle wanted to rip the fenders off and make it a hotrod in 1966 so he too has a chapter written in this cars history.
After the car sitting for 50 years (locked up by gramps) in the garage to prevent the "destruction" my uncle wanted to preserve the car with some hints of hotrod so this is where we are...
FYI if anyone can identify the wheels on the car in the picture please let me know what they are. Hub caps? Rock shields? No clue here...
Old 02-15-2022, 07:42 PM   #9
DNLs1930
DNLs1930's Avatar
Originally Posted by tinkirk View Post
these are radials back are 235r85/16 not positive on the front i will need to look at them to know for sure
sent from my iphone using tapatalk
me likes!!!!
Old 02-16-2022, 08:10 AM   #10
nkaminar
nkaminar's Avatar
A lot of Model A's got converted over to 16 inch wheels early on. I suspect it may have been do to availability of tires or fashion as the newer cars had balloon tires.
I had 16 inch wheels on my first 1930 Model A in the 1960's. I liked the look of the earlier wheels and tires so I switched back to originals. I discovered that the car steered easier with the 19 inch tires. If you are going to stick with the 16 inch wheels you may want to consider switching over to a F-100 steering box.
Great photo, by the way.
Old 02-16-2022, 08:47 AM   #11
48fordnut
48fordnut's Avatar
The wheels you are trying to identify on the model a coupe look to be wide 5, 37-39 ford with the corresponding hub caps.
48fordnut is offline   Reply With Quote
Old 02-16-2022, 09:55 AM   #12
Fred A
Fred A's Avatar
The wheels on the coupe do appear a bit like the wide fives, but a closer look will show the spokes beneath the wheel covers. Fred A
Fred A is offline   Reply With Quote
Old 02-16-2022, 12:00 PM   #13
Cool Hand Lurker
Cool Hand Lurker's Avatar
Back in the 20's, 30's & 40's the regular day-to-day users of Model A & T Fords would make modifications to their cars. It was way of life for them. It was a way of life for the Model A & T. It wasn't hot rodding. Changing the size or look of a wheel was normal. Even now, changing the look a little is still normal. Like driving lights in front, LED tail lights that can actually be seen at night. To be a normal Model A it doesn't have to be a perfect Model A unless you are looking to be judged. By a real judge, not a casual observer on a bad day.
I like snow tires. I am a normal Model A owner.
DNLs1930, don't worry about it. Find the wheel you want to keep it like the family wanted it to be.
Cool Hand Lurker is offline   Reply With Quote
Old 02-16-2022, 12:18 PM   #14
chrs1961815
chrs1961815's Avatar
Back in the 40s to the 60s it was common to go with V8 wheels to lower the car and soup it up. Kind of like a light version of hot rodding. Just going for the look.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 02-16-2022, 01:32 PM   #15
AL in NY
AL in NY's Avatar
Try the link below. A lot of information on 16 inch wheels and tires. I went with a Westlake SU318 225/75R16 passenger car tire. If you drive your car a lot, you'll really like these radials.
https://www.fordbarn.com/forum/showt...light=westlake
AL in NY
AL in NY is offline   Reply With Quote
Old 02-16-2022, 07:50 PM   #16
DNLs1930
DNLs1930's Avatar
YES there are spokes in the wheels behind the hubcaps.
I just have not been able to find a hubcap that matches that design.
For all I know they are not ford wheels at all. I'm sure they installed whatever they could get/find so next step is to figure out what wheels would fit the ford lug pattern and expand the search...
Old 02-16-2022, 07:57 PM   #17
DNLs1930
DNLs1930's Avatar
Thanks for the link LOTS of car pics there!!
700x16 and 600x16 seems to be the not too hotrod look
Old 02-17-2022, 05:15 AM   #18
Bruce of MN
Bruce of MN's Avatar
I’ve read that 16” wheels were put on during WW2 tire rationing because those used tires were more available.
Bruce of MN is offline   Reply With Quote
Old 02-25-2022, 03:45 PM   #19
DNLs1930
DNLs1930's Avatar
THANKS for the follow up on the tire sizes!!
Old 02-25-2022, 04:18 PM   #20
gdmn852
gdmn852's Avatar
The last year Ford used spoke wheels was 1935 ,36 to 39 used the wide spaced type rims similar to older VW bugs. But as you said may not be Ford . I can remember when I first got my first Model A(late 1960s) “old timers “said the older sized tires weren’t available so they went to 16 and 15 inch rims and tires.In fact that is what the Model A had when I bought it,1935 Ford ,and one of the first things to find were 19 rims .
gdmn852 is offline   Reply With Quote
