Old 03-09-2011, 05:13 PM   #1
Coupe35
Default Who makes the round chrome button for 35 ignition
On the ignition switch for a 35/36 car, there is a chrome button about 3/4" diameter that goes in and out when you turn the key on or off. It's pressed on the end of the ignition shaft. Does anyone know if this part is being reproduced.
Coupe35 is offline   Reply With Quote
Old 03-09-2011, 05:22 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: Who makes the round chrome button for 35 ignition
I don't think it is being reproduced. Someone should reproduce it, however.
Old 03-10-2011, 09:36 AM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
If you know someone who owns a lathe they could make one for you. Instead of doing a press fit, it could be made to fit loose and then drilled and tapped for a small set screw to hold it on the shaft.
John
Old 03-10-2011, 10:13 AM   #4
Lawson Cox
Lawson Cox's Avatar
All that work for an unauthentic repro part? Set screw is a NO NO.
Old 03-10-2011, 10:47 AM   #5
FRANK PKNY
FRANK PKNY's Avatar
old rebuilt switches are availabe on Epay around $125 to $150
FRANK PKNY is offline   Reply With Quote
Old 03-10-2011, 11:08 AM   #6
deuce lover
deuce lover's Avatar
Bob Drake has a kit for the 40 and I believe the button is the same.Its made from stainless.
deuce lover is offline   Reply With Quote
Old 03-10-2011, 11:38 AM   #7
JM 35 Sedan
SS would be my material selection. Then when polished would look like chrome. One small allen head set screw positioned correctly to hold it on the shaft would probably never be seen if car is too be judged. I'm surprised that Henry didn't make it this way but maybe he wanted to save a few cents.
John
Old 03-10-2011, 09:56 PM   #8
jfcrash
jfcrash's Avatar
I purchased that end cap from Roy N a few years ago as a separate item (not in a kit), at the time his item number was T-06-03.
Not sure if its still offered......give him a call 734-654-9450
______________________________________________
jfc
I couldn't repair the brakes, so I adjusted the horn louder....
jfcrash is offline   Reply With Quote
Old 03-11-2011, 08:32 PM   #9
dave collette
dave collette's Avatar
Roy N. supplies it separatly in his catalog.I bought one and it fits perfect on my 35 roadster. Dave C.
dave collette is offline   Reply With Quote
