Old 02-11-2022, 04:18 PM   #1
Lawson Cox
Lawson Cox's Avatar
Default Off Topic. Sand blaster
I have an old gravity fed sand blaster. It has worked fine for years. It was working fine as I was cleaning up my transmission case and then it just quit blasting sand and started blowing air/sand up from the bottom of the hopper. It just reversed cycle somehow. I thought it may be the old dry rotted hose so I replaced everything. Same thing. I have 1/2 a transmission case to finish and I'm NOT going to invest in a new sand blaster just to finish that job. Manufacturer is out of business. Bead blasted a few small things in the cabinet while I pondered this enigma. (I can't put transmission in bead blasting cabinet.) Any ideas as to a solution?
Old 02-11-2022, 04:41 PM   #2
swedishsteel
Default Re: Off Topic. Sand blaster
Sounds like maybe the air passage in the gun is blocked, pushing air pressure backwards from the gun into the sand hose. Take your gun apart and see if anything amiss in it.
swedishsteel is offline   Reply With Quote
Old 02-11-2022, 04:43 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
Sounds like the gun/blast nozzle is so worn internally that it no longer is able to siphon media. May need new nozzle.
Old 02-11-2022, 05:06 PM   #4
koates
Place your gloved hand over the nozzle tightly and operate the trigger with your other hand on and off in bursts a few times. This should unblock the sand hose. Regards, KEVIN.
koates is offline   Reply With Quote
Old 02-11-2022, 07:25 PM   #5
Lawson Cox
Lawson Cox's Avatar
I checked the nozzle and it looked pretty good. One drill size larger than a new one. I changed it anyway. I'll check it out tomorrow.
Old 02-11-2022, 07:25 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
YUP....what Kevin said! Squeeze your thumb tightly over the orifice and burp the gun a few times! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 02-11-2022, 07:27 PM   #7
Lawson Cox
Lawson Cox's Avatar
Kevon. I replaced the sand hose but it still works in reverse. Changed to a new nozzle which I will try out tomorrow.
Old 02-11-2022, 07:33 PM   #8
Lawson Cox
Lawson Cox's Avatar
About all I know about the gun is how to change nozzles, which I have done but haven't tried it yet. Will do that tomorrow. I can't see any way to do much else, but I do see a large nut toward the rear of the gun. I'll remove that and take a look see.
Old 02-11-2022, 07:44 PM   #9
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by Lawson Cox View Post
About all I know about the gun is how to change nozzles.
Second verse....Same as the first!
T5 W/TORQUE TUBE
Old 02-11-2022, 08:35 PM   #10
51 MERC-CT
51 MERC-CT's Avatar
Inspect the internal casting.
Had one that was so eroded internally that it would not siphon the sand from the hopper.
Old 02-11-2022, 08:40 PM   #11
34PKUP
34PKUP's Avatar
As quoted in first post, " then it just quit blasting sand and started blowing air/sand up from the bottom of the hopper."
It is already blowing back into the hopper?
34PKUP is offline   Reply With Quote
Old 02-11-2022, 09:50 PM   #12
Lawson Cox
Lawson Cox's Avatar
Yes. I changed nozzles and will check it tomorrow after my first great granddaughter's second birthday party, then I will venture into the unknown and remove the large nut and see what lies beneath
Old 02-11-2022, 09:56 PM   #13
bbrocksr
The gun/nozzle is plugged.
Bill
bbrocksr is offline   Reply With Quote
Old 02-11-2022, 10:17 PM   #14
Lanny
Lanny's Avatar
When you take off the large nut, don't let the spring in there go flying.
It is just the spring that pushes the trigger back to off position.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 02-11-2022, 10:25 PM   #15
Lawson Cox
Lawson Cox's Avatar
Bill
So, how do I go about unplugging it? I never had this problem before. Thanks.
Old 02-11-2022, 10:38 PM   #16
Lanny
Lanny's Avatar
Also, if the nozzle gets pushed into the gun to far, and covers up part of the siphon hole,
that the hose goes on, that would act as if the nozzle is plugged.
Old 02-11-2022, 10:58 PM   #17
Lanny
Lanny's Avatar
One last thing, make sure that your sand is NOT Moist, it must
be super-super dry.
Old 02-12-2022, 01:37 AM   #18
V8COOPMAN
V8COOPMAN's Avatar
For the THIRD time, Lawson......Squeeze your thumb tightly over the orifice and burp the gun a few times! DD
T5 W/TORQUE TUBE
Old 02-12-2022, 03:00 AM   #19
bbrocksr
When the gun/nozzle is plugged it is already blowing back through the pickup hose, same as putting your thumb over it.
Lawson, to unplug it take the gun out of the machine and put the shop air hose against the nozzle and pull the trigger and blow back through the gun,
with the trigger held open and blowing backwards through the gun should clear it.
Bill
Old 02-12-2022, 01:17 PM   #20
1952henry
1952henry's Avatar
[QUOTE=V8COOPMAN;2103856]For the THIRD time, Lawson......Squeeze your thumb tightly over the orifice and burp the gun a few times! DD[/QUOT
This^^ has worked for me.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
