Old 02-04-2022, 10:40 AM   #1
Kube
Kube's Avatar
Default Hubcap ID help please :)
Any help identifying these would be greatly appreciated. Thanks in advance men
Old 02-04-2022, 11:02 AM   #2
38 coupe
38 coupe's Avatar
Default Re: Hubcap ID help please :)
Top middle is 54 car
Top right is late is 52-53 car
Not sure on the rest. Is bottom right from a Plymouth?
Old 02-04-2022, 11:05 AM   #3
Bruce_MO
Top row L to R: '46 Mercury, '54, 53
Not sure enough on the others
Bruce_MO is offline   Reply With Quote
Old 02-04-2022, 11:19 AM   #4
Kube
Kube's Avatar
Thanks guys. I knew you guys could help. We're getting there!
Oh, yep, I snuck a Plymouth cap in there
Old 02-04-2022, 11:24 AM   #5
38 coupe
38 coupe's Avatar
Is the center right one smooth from outer edge to the center bullet? If so, then 49-50 passenger car. If not, maybe aftermarket repop of same?
Center one is mid to late 50s "poverty" cap from when full covers were common. A site I found says 1956, but I can't verify that.
I'm no help on the Mercury and Plymouth units.
Old 02-04-2022, 11:26 AM   #6
Road Trip
Second row left appears to be an Olds.
Bottom right is '50 Plymouth.
Road Trip is offline   Reply With Quote
Old 02-04-2022, 11:27 AM   #7
deuce5wndw
deuce5wndw's Avatar
Second row center is 1956 and the one to the right is 49-50, bottom row first one is 1961-62 Mercury and I think it is correct for some of the mercury trucks.
deuce5wndw is offline   Reply With Quote
Old 02-04-2022, 11:07 PM   #8
fordor41
fordor41's Avatar
center one looks like '57 Ford. center right '51 Ford, maybe!
fordor41 is offline   Reply With Quote
Old 02-05-2022, 12:52 AM   #9
Lanny
Lanny's Avatar
Yup,, second row-center is '55 and '56 Ford
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is online now   Reply With Quote
Old 02-05-2022, 09:13 AM   #10
deuce5wndw
deuce5wndw's Avatar
Lanny the only difference in 55-56 is the color of paint. The 55 is red and 56 is white.
Dale
Old 02-05-2022, 11:37 AM   #11
TJ
TJ's Avatar
Center row left is '50 Olds.
Old 02-05-2022, 01:02 PM   #12
MGG
MGG's Avatar
Center row right looks like what was on our 1950 Ford sedan. Bottom row left was what was on our 1965 Mercury Comet.
MGG is offline   Reply With Quote
Old 02-05-2022, 06:22 PM   #13
mercman from oz
mercman from oz's Avatar
Identification of Hubcaps are Left to Right - Top Row 46 Mercury, 54 Ford, 53 Ford. Middle Row 54 Oldsmobile, 56 Ford and 49/50 Ford - Bottom Row 62/63 Mercury Meteor and Plymouth. Regards Mercman <><
Old 02-05-2022, 06:59 PM   #14
mercman from oz
With regards to the 1952 - 1953 - 1954 Ford Hubcaps, they are all different. On the 52 Hubcap, the FORD lettering is on a slant. On the 53 and 54 Hubcap, the lettering is vertical and is the same for both years, but the indent for painting the centre of the 54 Hubcap has been added. Note, that Ford Australia painted the Centres Black, while in the USA, they were painted Red. For detail, check out the above photos.
Old 02-12-2022, 04:19 PM   #15
Kube
Kube's Avatar
Thanks a ton you guys! I am obliged to you all for the help.
