Old 01-25-2022, 03:55 PM   #1
Shoebox
Shoebox's Avatar
Default Thread Chase Kit Recomendations
So I need to chase all the bolt holes in my flathead block and know enough to not use taps, rather thread chase tools. I have done a preliminary google, saw some stuff on Amazon, but many of the kits have a metric content, which I don't want/need. Anyone have a kit/brand recommendation or is it better to buy individual ones as needed? I will check with my local Ace Hardware but I believe I'll end up having to order something. Thanks!
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 01-25-2022, 04:10 PM   #2
rockfla
rockfla's Avatar
Default Re: Thread Chase Kit Recomendations
I'll send you mine to use IF you like!!!! Thread chasing/cleaning kit NOT a tap and die set
Old 01-25-2022, 04:14 PM   #3
Shoebox
Shoebox's Avatar
Well, that is very generous,... I'm not opposed to buying a good kit, or perhaps you have accumulated these over time. I will PM you. Thank you.
32 Ford roadster
39 Mercury Towncar
Old 01-25-2022, 04:17 PM   #4
corvette8n
corvette8n's Avatar
I was lucky bought a Craftsman set when Sears was going belly up, looks a lot like the one in the picture I paid less than $50. I didn’t think I would use the metric, but I have used it on my truck, wife’s Toyota and lawnmower in addition to the SAE on a couple of flathead blocks.
File Type: jpg 7BF0F7F8-591F-49C3-B166-6A1607B12947.jpg (29.3 KB, 50 views)
Old 01-25-2022, 04:17 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by Shoebox View Post
So I need to chase all the bolt holes in my flathead block and know enough to not use taps, rather thread chase tools. Anyone have a kit/brand recommendation or is it better to buy individual ones as needed?
Why not cut a slot in a few necessary bolt sizes to create (for next to nothing) your own chasers? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-25-2022, 04:25 PM   #6
Shoebox
Shoebox's Avatar
Smile Re: Thread Chase Kit Recomendations
True, I have done that once or twice. Just looking for an excuse to buy more tools.
32 Ford roadster
39 Mercury Towncar
Old 01-25-2022, 04:25 PM   #7
Shoebox
Shoebox's Avatar
Ya, that's the sort of thing I'm thinking of.
32 Ford roadster
39 Mercury Towncar
Old 01-25-2022, 04:32 PM   #8
rockfla
rockfla's Avatar
Scott
Post #4, that picture is my exact kit!!!!
Old 01-25-2022, 04:52 PM   #9
Tim Ayers
I have this kit and the "deluxe kit-it includes a few more". I use these multiple times a week. Best tool investment I've made.
I forget who actually makes it (Apex tool maybe), but it the same kit sold on Snap On trucks, etc.
Make sure you get the US-made one. Well worth the purchase.
Old 01-25-2022, 05:13 PM   #10
drfromnc
I bought one from Summit Racing. Seems to work well and it was $37.99
Summit Racing part #SUM-900199 - Summit Racing™ Complete Thread Cleaning Kits
Also had to buy 2 individual ones from eBay for head coolant ports and drain cock ports in the block.
drfromnc is offline   Reply With Quote
Old 01-25-2022, 05:32 PM   #11
ford38v8
ford38v8's Avatar
For any Newbys reading this thread, don’t even chase the threads on an early banjo if you can help it. Those threads are made purposely tight to help prevent oil leaks. They still need Locktite, but they should not spin in easily with your fingers.
Alan
Old 01-25-2022, 06:17 PM   #12
DavidG
DavidG's Avatar
Alan,
Very, very good advice.
DavidG is online now   Reply With Quote
Old 01-25-2022, 06:43 PM   #13
Kube
Kube's Avatar
I'd done this very often during my career. This method aids in removing the debris at the same time. Just apply a small amount of grease...
Old 01-25-2022, 06:59 PM   #14
Tim Ayers
The nuts that come in the kit have save countless bolts that have had boogered up threads.
Pick up that inexpensive kit from Summit and you'll see the difference. Chasers have been life savers when trying to reuse old Ford bolts and nuts.
Old 01-25-2022, 07:24 PM   #15
Shoebox
Shoebox's Avatar
I believe you Tim.
32 Ford roadster
39 Mercury Towncar
Old 01-25-2022, 08:41 PM   #16
Tim Ayers
I believe you Tim.
Haha. I'm sure you do, but I replying to DD's post.
Old 01-25-2022, 09:26 PM   #17
[email protected]
I see you are from Wisconsin, you must be familiar with Fleet-Farm I purchased a set of thread chasers from Fleet-Farm.
abguse67@gmail.com is offline   Reply With Quote
Old 01-25-2022, 09:49 PM   #18
Scotty's 52 F3
Scotty's 52 F3's Avatar
Jawco is a brand made in U.S.A.
Scotty's 52 F3 is offline   Reply With Quote
Old 01-25-2022, 10:23 PM   #19
Craig CT
Craig CT's Avatar
Hello Shoebox; Not a kit but you might try different size firearms bore cleaning brushes on a tap handle or an electric drill. Good luck, Craig.
" When I was a boy of fourteen, my father was so ignorant I could hardly stand to have the old man around. But when I got to be twenty-one, I was astonished at how much he had learned " Mark Twain.
Craig CT is offline   Reply With Quote
Old 01-25-2022, 10:28 PM   #20
RalphG
RalphG's Avatar
Ok, I will show my ignorance here by asking why not use tap and die set to clean up the thread on used nuts and bolts on anything? I have a good (Hanson) tap and die set and have used it for years to clean threads on any rusty or damaged threads I've had to work with. No ill effects that I've ever noticed.
RalphG is offline   Reply With Quote
