Old 01-24-2022, 10:21 AM   #1
adileo
adileo's Avatar
Default F1 6 volt electric question
Hey Gents
I added turn signals about 3 years ago (seven wire) with led rear tail lights (with resistors in line for each) and utilize front parking lights for turn signals.
All was working well until last night. I noticed when headlights are on. I have tail lights, but no brake or turn signals. During day time all works as it should but I noticed my flasher is slower than normal.
Do you think it’s the flasher or the cheap turn signal switch has crapped out.
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 01-24-2022, 11:11 AM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: F1 6 volt electric question
Originally Posted by adileo View Post
Hey Gents
Andy, do any of the four corners blink? Do your brake lamps light?
A new flasher is cheap and easy to replace. That may prove to be a quick way to ether fix the issue or eliminate that part of the system as a possible fault.
Old 01-24-2022, 11:21 AM   #3
adileo
adileo's Avatar
Hi Mike
Day time driving, yes brakes and turn all good
Night time headlights and taillights work, but no brake or turn.
Found out last night, coming home from Tom’s shop I would have grabbed a flasher from Tom had I known
Thanks
Andy
1952 F1
Old 01-24-2022, 11:38 AM   #4
corvette8n
corvette8n's Avatar
Check your grounds also, had to do that with a ‘50 sedan I had. I removed all the ground wires and wire brushed every connection, I even added extra flat braided cables from engine to frame and frame to body.
Old 01-24-2022, 04:35 PM   #5
1931 flamingo
1931 flamingo's Avatar
Are the headlights putting too much of a "load" on the electrical system??
Paul in CT
Old 01-24-2022, 04:48 PM   #6
Kube
Super Moderator
Kube's Avatar
Hi Mike
Just to be clear... all lamps work properly during the day?
When you say NO brake or turn, that includes the front lamps as well?
Did they all work, all the time, in the past?
Old 01-24-2022, 05:10 PM   #7
adileo
adileo's Avatar
Yes all brake and turn signals work during day
Yes all worked for past 3 years.
Yes fronts too don’t work with headlights on.
Update, I found 6 volt flasher in my stock. Installed and same results. At this point I think turn signals switch is faulty.8
Thanks
Andy
1952 F1
Old 01-24-2022, 06:39 PM   #8
5851a
The only part of the 2 systems connected would be your tail lamps? The only way the headlamps and signals are together is a common ground in the tail lamps. Just my guess that you may have a sketchy ground in the tail lamps. LED's and resistors kind of throw wrench into the works for me to understand.
5851a is offline   Reply With Quote
Old 01-24-2022, 06:47 PM   #9
adileo
adileo's Avatar
Thanks someone else also mentioned grounds. I’ll check tail light grds, first.
Thanks
Andy
1952 F1
Old 01-25-2022, 01:50 AM   #10
Eagle43
Just wondering what you did with the front park lights. Originally they are set up for single filament bulbs. Are both the park light wiring and the signal light wiring connected together to the same filament? If so the flashers won't show since the park lights are giving power all the time.
I'm just working on mine. I switched out the single filament connector and put in a double for 6V 1157 LED bulbs. I just found and ordered some positive ground LED 6V 1157s from Aliexpress. You shouldn't need resistors if you wire in dash bulbs. There are spots for them on the speedometer to indicate turns.
Eagle43 is offline   Reply With Quote
Old 01-25-2022, 06:47 AM   #11
adileo
adileo's Avatar
Thanks, I wired them for just turn.
Thanks
Andy
1952 F1
Old 01-25-2022, 10:11 AM   #12
adileo
adileo's Avatar
Thanks guys!
For the next Barner: It was the ground. I had them grounded to the frame. Guess after 3-4 years daily driving bare metal rusted.
Thanks
Andy
1952 F1
Old 01-25-2022, 10:28 AM   #13
corvette8n
corvette8n's Avatar
Thanks guys!
Glad you found the problem, I spray my grounds with fluid film and my battery terminals also. I used to have a problem with my riding lawnmower battery getting all corroded over the winter, I sprayed it liberally with fluid film and it looks like new in the spring.
Old 01-25-2022, 10:45 AM   #14
joe 1950
joe 1950's Avatar
what is fluid film where do you get it is it like blinker fluid ��
joe 1950 is offline   Reply With Quote
Old 01-25-2022, 11:41 AM   #15
V8COOPMAN
V8COOPMAN's Avatar
Lowes, Amazon, Grainger, eBay..........! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-25-2022, 07:39 PM   #16
joe 1950
joe 1950's Avatar
thanks coopman never heard of it up here in wi i’ll try it my wife says i’m old and senile but i don’t know what that means Ha Ha thanks
Old 01-25-2022, 10:31 PM   #17
V8COOPMAN
V8COOPMAN's Avatar
joe .....I've never heard of the stuff, either. Done just fine ALL these years without having to buy some new 'Miracle Jizz'! Hell, smear some Naval Jelly or Petroleum Jelly out of your medicine cabinet on these bare spots, just like you've always done on battery posts, etc! DD
T5 W/TORQUE TUBE
Old 01-25-2022, 11:34 PM   #18
Tinker
Tinker's Avatar
90% of electrical issues are ground issues.
