Old 01-21-2022, 04:19 PM   #1
Wehill99
Wehill99's Avatar
Default Purolator Oil Filter Question
I found a cool old Purolator oil canister and I wondered if I could pick up a newer filter for it. Pictures are attached. It has "Kit 428" on the box.
The dimensions of the element are 3-7/16" outer diameter, 4-1/4" length, and 11/16" inner hole.
Has anyone seen this and have the # of a newer replacement element?
Wehill99 is offline   Reply With Quote
Old 01-21-2022, 04:59 PM   #2
aussie merc
aussie merc's Avatar
Default Re: Purolator Oil Filter Question
go to fleetguard or baldwin site and crossover the # should give you the direct replacement or check the purolator site it may still be a good #
aussie merc is offline   Reply With Quote
Old 01-21-2022, 05:52 PM   #3
19Fordy
19Fordy's Avatar
I wonder if any of these would match your filter?
Open and scroll down.
https://shop.advanceautoparts.com/fi...28i-oil-filter
Old 02-08-2022, 08:49 AM   #4
Wehill99
Wehill99's Avatar
Just a FYI that I found the Wix website the most helpful. Just can search filters based on dimensions. I found a Wix number that ended up converting to a NAPA #. Picked the filter cartridge up at NAPA.
Old 02-08-2022, 07:24 PM   #5
cas3
I buy filters on ebay. lots of deals there. Old, new, buy em by the dozen, what ever you like
