Old 01-17-2022, 06:34 PM   #1
klrh20frank
Default front Radius ball not lined up with Socket
working on 29 coupe.
Removed engine and transmission to swap out engine. installed same and have a problem. rear motor mounts (Float-A-Motor) line up with attachment to engine. The radius ball is about one half ball aft of the socket in the engine.
dloes anyone have any ideas what might cause this. i appreciate anysuggestions. Thanks
Frank
klrh20frank is offline   Reply With Quote
Old 01-17-2022, 07:22 PM   #2
Rodrelic
Default Re: front Radius ball not lined up with Socket
Guessing jack up the frame until can bolt into place?
Rodrelic is offline   Reply With Quote
Old 01-17-2022, 07:29 PM   #3
J Franklin
J Franklin's Avatar
Where is your come-along?
Old 01-17-2022, 10:01 PM   #4
klrh20frank
need engine to move back.where do you recomend i pull from?
Old 01-17-2022, 10:13 PM   #5
Utopia Texas
Utopia Texas's Avatar
Apply the hand brake then jack up the front end where the front tires are barely off the ground, then place Jack stands under the frame on both sides near the front. By having the front spring, axle and wheels hanging you can then pull from the front to get the ball into the socket. Once lined up it may then take a floor Jack to raise the ball into the socket.
Utopia Texas is offline   Reply With Quote
Old 01-17-2022, 11:45 PM   #6
klrh20frank
thanks, I will try that tomorrow.
Frank
Old 01-18-2022, 02:40 AM   #7
J Franklin
J Franklin's Avatar
Talking Re: front Radius ball not lined up with Socket
That will need the use of a cutting torch and some creative welding!
Old 01-18-2022, 10:48 AM   #8
katy
katy's Avatar
Loosening the front spring U bolts will help.
Old 01-18-2022, 10:57 AM   #9
KenBolton
It isn’t the engine that needs to move back but rather the front axel needs to come forward. Reminds me of my first engine install after towing a running gear and cab several miles home. Had to “stretch it out” with a tractor gently pulling on each end.
KenBolton is offline   Reply With Quote
Old 01-18-2022, 11:50 AM   #10
Russ/40
Russ/40's Avatar
Good grief, Charlie Brown !
Russ/40 is offline   Reply With Quote
Old 01-19-2022, 04:34 PM   #11
BillCNC
BillCNC's Avatar
When I rebuilt my front end, I assemble everything with slightly more than finger tight, then once everything is attached, I then start tightening everything up. Starting at one end and tightening everything as I go along, never seemed to work out that well for me.
Regards
Bill
BillCNC is offline   Reply With Quote
Old 01-19-2022, 08:10 PM   #12
larrys40
Frank,
It’s not all that uncommon for a ball to be off a little. Crossmembers, springs, etc an have a affect. I use a model T jack at the back right in front of the ball to get the ball and socket in place. Unless it is way off it usually slips into place, even if significantly off.
Put you cap in place, use grease on the ball and socket and try it.
The T style jack works great.
Larry Shepard
larrys40 is offline   Reply With Quote
Old 01-19-2022, 10:47 PM   #13
Afordman31
Afordman31's Avatar
I used my porta-power jack and pushed the axle out from the motor mount on passenger side!
Afordman31 is offline   Reply With Quote
