Old 01-10-2022, 11:09 PM   #1
TMarsh
Default Lost bolt
My starter would not engage flywheel. Discovered bolt came out of bendix. I suspect the bolt is in the bell housing. Should I be concerned with the loose bolt
and try to fish it out or just leave it in. Suggestions for getting the bolt out will be greatly appreciated, if the general opinion is to remove it.
TMarsh is offline   Reply With Quote
Old 01-10-2022, 11:27 PM   #2
alexiskai
alexiskai's Avatar
Default Re: Lost bolt
I've heard of successful retrievals using something like this:
https://shop.snapon.com/product/Magn...(BLue)/DPTM24A
Old 01-10-2022, 11:40 PM   #3
Bill G
Bill G's Avatar
I believe you should fish it out. When the same thing happened to me I researched past posts which concerned me enough to spend about 45 minutes on that same fishing trip.
Bill G is offline   Reply With Quote
Old 01-10-2022, 11:48 PM   #4
Dougs 28
Dougs 28's Avatar
Use a short length of garden hose and tape it to the end of you’re shop vac hose so it transfers the suction to the short garden hose, after taking the starter out, shove the hose into the flywheel housing and you should be able to suck the bolt out.
Dougs 28 is offline   Reply With Quote
Old 01-11-2022, 08:08 AM   #5
jak
i put a large magnet on the flywheel. Than using the hand crank turned the engine over slowly. the magnet sucked up the bolt and any broken pieces of the tab washer. I tried all of the other methods out there, but this was by far the fastest way to do it. I know keep the magnet in the tool box for any future needs.
jak is offline   Reply With Quote
Old 01-11-2022, 09:45 AM   #6
Redbird
Redbird's Avatar
Don't forget that the bolts should have a French locking tab/ fold over washers for the bolt heads. Then it won't happen again.
Redbird is offline   Reply With Quote
Old 01-11-2022, 10:36 AM   #7
Rodrelic
Had the same thing when I was working toward the power unit running. The starter was removed and it bench ran but bendix did not kick. The bolts were loose and only one had a point and the other was undersize. Found the right bolts and lock plate, used different spring. Cranks now, but can’t believe everything did not fall apart inside there. A good indication I should proceed with skepticism on this one
File Type: jpg D868DDA8-098A-45E9-BA6B-7CBC21262C0F.jpg (89.3 KB, 78 views)
Rodrelic is offline   Reply With Quote
Old 01-11-2022, 12:27 PM   #8
TMarsh
Just a little bit of follow up. I had just put on an Optima battery, 6 volt, and it has a lot of cold cranking amps. I suspect high amps caused the bolt to fail, it was installed correctly with bent over tab. I will follow up when I retrieve parts. Thanks for the suggestions on getting the parts out.
Old 01-11-2022, 12:52 PM   #9
nkaminar
nkaminar's Avatar
I like the US made modern Bendix drive because there is no bolt to come loose or spring to break. There is a screw to lock the drive on the shaft but it is captured by a spring loaded washer.
Old 01-11-2022, 01:05 PM   #10
Herb Concord Ca
I used a flexible wand (that held its bend) with a magnet on the end. First try picked up the bolt!
Herb Concord Ca is offline   Reply With Quote
Old 01-12-2022, 03:49 PM   #11
TMarsh
Just a follow up, thanks Herb Concord Ca, used HF flexible magnet and picked up bolt and french washer first try.
Old 01-12-2022, 04:14 PM   #12
Redbird
Redbird's Avatar
Was washer broken?
Old 01-12-2022, 04:43 PM   #13
gary678*
Happened to me. Easy remedy: use a thin extendable magnet rod and fish arounds a little and it should come right out. Good luck!
gary678* is offline   Reply With Quote
Old 01-12-2022, 06:30 PM   #14
TMarsh
The washer was bent a little, do not think I put a new one on when I rebuilt the starter.
Bolt was OK. Have new bolts now, and washers.
Old 01-12-2022, 06:51 PM   #15
Oldgearz
That is most ingenious JAK. I've had this happen to my tractors but never thought of this. I will next time.
Oldgearz is offline   Reply With Quote
