Old 01-08-2022, 07:20 PM   #1
keviny
Default Cab body fasteners
What fasteners were used fasten 1929 model a closed cab parts. Were they square head. Were they painted with the cab?
keviny is offline   Reply With Quote
Old 01-08-2022, 07:50 PM   #2
31Tudor
31Tudor's Avatar
Default Re: Cab body fasteners
Square nuts were used along the gas tank to firewall, these bolts also had a smaller taller head. Then square nuts were also used to fasten the top have to the bottom half of the back of the cab. The body was completely assembled then painted, so any bolt/ nut holding the cab together, along with the wood, would have been painted.
31Tudor is offline   Reply With Quote
Old 01-08-2022, 08:54 PM   #3
keviny
Thanks, that helps. I haven’t seen any cab bolt kits on the market
Old 01-08-2022, 09:15 PM   #4
31Tudor
31Tudor's Avatar
Maybe not like a body bolt kit, but there are some kits for certain parts. I think the others do too, but in Brattons, in the pickup section is the firewall bolts, #12820, rear window kit, #34160. Then there is a belt rail kit, the dispatch pocket kit and roof kit; all for pickup.
Old 01-08-2022, 09:47 PM   #5
keviny
Thanks, that’s quite a catalog
