01-04-2022, 08:14 AM | #1 |
Clutch Release Lever
Hi, thanks for the recent advice. I mustered up the courage to drop the transmission. I know, I know, anyone can take @#$& apart! But I realize IÂ’m the novice who will be putting it back together. Indeed the rivets that attach the lever to the bell housing failed. My question, can I use a typical machine bolt with tapered head or do have to locate the elusive hardened bolt? I have found the kit that comes with a bracket ( different than the existing bracket) but how could I know if the accompanying screws are hardened? I donÂ’t mind paying the approximate 20 bucks. It would be worth it not to have a redo in the near future. Thanks and God Bless.
01-04-2022, 10:36 AM | #2 |
Re: Clutch Release Lever
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... |
01-04-2022, 07:32 PM | #3 |
I just swapped out the older style clutch rod so I can run f1 style clutch linkage
01-04-2022, 07:57 PM | #4 |
I was not able to find any flat head bolts that are hardened. Long story so I’ll keep this short. I ordered the bracket and screws from “Melvin’s”, I want to believe the manufacturer has it right, however I was not able to get that spec. If you don’t mind I have no idea what f1 linkage is. I think I should let on that this a 65 Falcon, 200 ci. 6 cyl. Synchronized manual 3 speed on the floor with a Hurst Shifter. If I can improve or up grade to some better linkage system I’d love to know about it. Thanks
01-04-2022, 08:32 PM | #5 |
If you found this -
- https://www.classicindustries.com/pr...rts/7522d.html ... you should be good to go. I would like to know what f1 refers to myself ...
01-05-2022, 08:26 AM | #6 |
01-05-2022, 09:09 AM | #7 | |||
Your pressure plate will not be that strong and hopefully they will work for you.
01-05-2022, 09:55 AM | #8 |
Can you elaborate on that? You know something I don't and I need to learn ...
01-06-2022, 08:40 AM | #9 |
Hi, I’ve got to wait for parts I ordered, I’ll get back here when/ if I get it all back together. I don’t know why that gentleman talked about f1 linkage, it is really designed for muscle or race cars. I also don’t believe it is a simple install. However remember I’m a goldfish in a big pond.
