Old 12-30-2021, 09:22 AM   #1
36coupe
36coupe's Avatar
Default 36-39 frame brackets
I have a 39 Ford frame bracket I was going to replace the 36 bracket on my frame but they have a different amount of drop which might affect clearance under the floor. The green book seems to list the same part number for both. The amount of the difference is approximately 1 inch.
Should I modify the bracket to match the 36? Or will it be OK to install as is?
36coupe is offline   Reply With Quote
Old 12-30-2021, 11:51 AM   #2
Karl Wescott
Karl Wescott's Avatar
Default Re: 36-39 frame brackets
The extra drop is for the wood floor support strips that were used 1935-36. The hole pattern is different 1935-36 (rod brakes), 1937-38 (cable brakes) and 1939-40 (juice brakes).
Photos of our reproductions:
Karl Wescott is offline   Reply With Quote
Old 12-30-2021, 03:55 PM   #3
JWL
I'll just have to say THANKS for this education Karl. I did not know this.
JWL is offline   Reply With Quote
Old 12-30-2021, 03:58 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
Me TOO! And, I sure didn't know that Karl was making those, either. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 12-30-2021, 04:11 PM   #5
JM 35 Sedan
JM 35 Sedan's Avatar
Me either...I didn't know Karl was reproducing these frame brackets....
Karl, how do I do an order for a pair of '35-'36 frame brackets? I'm guessing I go to your web site to order?
I need to repair two early model year '35 3w coupe frames by repairing or replacing those brackets. I believe I can straighten one set, but the other set has been severely chopped up, probably by a previous owner install some type of dual exhaust system, and then running over something that busted them up.
John
Old 12-31-2021, 08:12 AM   #6
36coupe
36coupe's Avatar
Thank you Karl, this site amazes me on how someone has the answer to everything.
I’m going to use this as a quick way to ID frames.
Old 12-31-2021, 12:02 PM   #7
TJ
TJ's Avatar
John, those damaged brackets show there are bad muffler shops vs good muffler shops.
Old 12-31-2021, 05:31 PM   #8
36coupe
36coupe's Avatar
I took an inch out of the 39 bracket and now it will clear the wood braces on the 36. Easy fix.
File Type: jpeg B3ED0E2D-C9F1-4536-BAFC-5D17991EBE1D.jpeg (113.7 KB, 23 views)
Old 12-31-2021, 07:23 PM   #9
36crazy
Also interested in how to order parts, I need a set of the body mount boxes for a 36
36crazy is offline   Reply With Quote
