Old 03-07-2011, 05:25 PM   #1
nellis003
nellis003's Avatar
Default '35 Ford resistor
Hi all,
Can anyone tell me what's normal behavior for the resistor on a '35 Ford dash harness? I just replaced the harness and resisitor on mine, and when the ignition switch is on the resistor gets pretty hot. I haven't had the chance to test it with the engine running yet.
Just want to know if I should be concerned or not.
Thanks,
Nick
nellis003 is offline   Reply With Quote
Old 03-07-2011, 05:55 PM   #2
Kahuna
Kahuna's Avatar
Default Re: '35 Ford resistor
Hi nick
The resistor is used to reduce the coil voltage. It will always be warm/hot in normal operation
Jim
Kahuna is offline   Reply With Quote
Old 03-07-2011, 06:32 PM   #3
Coupe35
My 35, I accidentally left the ignition switch on when the engine was not running. Luckily I was still out in the garage and smell something burning. It was the resistor. They must get a lot hotter when the engine is not running because when it is running it is still very warm to the touch but not like it did with engine off..
Coupe35 is offline   Reply With Quote
Old 03-07-2011, 07:58 PM   #4
nellis003
nellis003's Avatar
Okay, good to know. I think part of the trouble is that somewhere along the line someone installed a firewall cover on the cabin side, so the resisitor is mounted directly on fabric. I'm going to cut a metal plate and use some spacers to get it up and off the fabric, that way there won't be anything to burn.
Thanks, as usual,
Nick
Old 03-07-2011, 08:14 PM   #5
Kahuna
Kahuna's Avatar
Nellis
Generally the resistors are mounted on an insulated panel of sorts. Good plan to move it
Coupe 35-
in your case the points must have been closed. Had they been open, no problem would have occurred
Old 03-08-2011, 10:10 AM   #6
JM 35 Sedan
JM 35 Sedan's Avatar
Sometimes the residence wire connections on the board also become high resistance and cause the voltage to be too low to the coil. GM has a remedy to correct this problem. Maybe he will post that info here or you could pm him to get that info.
John
Old 03-08-2011, 10:19 AM   #7
FRANK PKNY
FRANK PKNY's Avatar
In my 39 pu I mounted it on the coil we often did this years ago to forgo any fire hazards.
FRANK PKNY is offline   Reply With Quote
