Old 12-18-2021, 04:34 PM   #1
oldredford
Default Fenton Headers
Fenton headers on a 1940 24 stud. One bolt will not thread. I give up. Not my car but doing an engine change for an elderly friend. I spent way too much time trying to get one bolt to thread. The design looks like the designer was on crack. POS Fenton headers they are...
oldredford is offline   Reply With Quote
Old 12-18-2021, 04:49 PM   #2
ford38v8
ford38v8's Avatar
Default Re: Fenton Headers
Front bolts are 7/16-16, all the rest are 3/8-16. Welcome to Ford Flatheads.
Alan
Old 12-18-2021, 04:53 PM   #3
KiWinUS
KiWinUS's Avatar
I have 4 original amazing sets that will bolt up with zero issues.
Old 12-18-2021, 05:30 PM   #4
Ronnieroadster
Ronnieroadster's Avatar
This fellow may have a set of off shore knocks off. The instructions should read due to accumulated tolerances some adjustment is required.
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Ronnieroadster is offline   Reply With Quote
Old 12-18-2021, 05:50 PM   #5
34PKUP
34PKUP's Avatar
7/16-14 is more likely not 7/16-16 if the thread size is the issue and not the alignment.
34PKUP is offline   Reply With Quote
Old 12-18-2021, 06:00 PM   #6
Krylon32
I have a set of original Fenton's and they appear to fit correctly
Krylon32 is offline   Reply With Quote
Old 12-18-2021, 06:21 PM   #7
ford38v8
ford38v8's Avatar
You are correct. My bad.
Alan
Old 12-18-2021, 06:29 PM   #8
Newc
Newc's Avatar
Ran into the same problem with engine holding [mount] exhaust plate-Some adjustment of holes required Newc
Old 12-18-2021, 10:35 PM   #9
cas3
I have a set, bought from a swap meet, but new-ish looking, I assume speedway Chinese mfr, and they fit just fine. Got a rat tail file?
Old 12-19-2021, 12:48 AM   #10
V8COOPMAN
V8COOPMAN's Avatar
Just be sure it's a USA-made rat-tail file! Otherwise, make'm funny holes! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 12-19-2021, 02:09 AM   #11
ford38v8
ford38v8's Avatar
I’m in before the hammer! ��
Alan
