Old 12-17-2021, 10:18 PM   #1
Pech33
Pech33's Avatar
Default Motor Mount Replacements for 40
What’s the deal with making the new replacements work? The bolt on the old ones are the same length as the new ones, the rubber is taller. How do you compress the new mount? Or do I cut it?
Pech33 is offline   Reply With Quote
Old 12-17-2021, 10:23 PM   #2
Bursonaw
Bursonaw's Avatar
Default Re: Motor Mount Replacements for 40
Bob Drake sells longer motor mount bolts.
https://bobdrake.com/products/1932-4...889be6f5&_ss=r
Sent from my iPad using Tapatalk
Bursonaw is offline   Reply With Quote
Old 12-17-2021, 11:21 PM   #3
Pech33
Pech33's Avatar
Why would vendors sell bolts that are too short? For $20, I can cut 1/4” off the rubber, what’s the difference? $20!
Old 12-18-2021, 05:26 PM   #4
Kube
Kube's Avatar
Hahaha! Why do venders sell a lot of crap that isn't correct and / or of good quality? Because guys buy the crap.
Cutting off 1/4" of rubber sure sounds counter-productive to me. With that sort of thinking I must ask, why replace them at all?
Motor mounts are designed at a specified height and of a specific (rubber) hardness.
Old 12-18-2021, 05:46 PM   #5
19Fordy
19Fordy's Avatar
I think the 40 Ford transmission mounts are the same as the motor mounts.
Old 12-18-2021, 06:07 PM   #6
Kube
Kube's Avatar
You are correct
The best reproduction mount kits I'd ever found were Drake's. The ones with the metal ring. I'd not purchased any in many years and wonder if they remain of good quality.
Note though, that while the mounts he'd sold were very accurate, the bolts included in the kits were too short.
Old 12-18-2021, 06:13 PM   #7
Zax40
Zax40's Avatar
I didn't have any issues with the Drake mounts and factory hardware on my '40. I jacked up the engine and replaced the front two first, then the rear two. Then I let the jack down so the engine was fully resting on all 4 mounts before I put the nuts on and started to torque them down.
But that being said it's possible the bolts had been substituted for longer ones sometime in the last 81 years.
Zax40 is offline   Reply With Quote
Old 12-18-2021, 06:36 PM   #8
V8COOPMAN
V8COOPMAN's Avatar
"Durometer" is a standardized way to measure the hardness of materials like rubber (elastomers) and plastics. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 12-18-2021, 06:40 PM   #9
cas3
One new thing learned today...check. thanks DD
cas3 is online now   Reply With Quote
Old 12-18-2021, 07:28 PM   #10
Pech33
Pech33's Avatar
Why would the taller rubber pad even be produced? I own them so I am pretty sure that I am cutting them down to fit.
Old 12-19-2021, 12:46 AM   #11
deuce_roadster
deuce_roadster's Avatar
I didn't see where these "tall" biscuits came from. They certainly don't have the metal band around them. Vintique maybe? Industria Argentina?
Old 12-19-2021, 12:53 AM   #12
petehoovie
petehoovie's Avatar
Old 12-19-2021, 09:39 AM   #13
DavidG
DavidG's Avatar
Judging from your photo, your old rubber mount is very compressed in the tapered area at the top. In other words, worn out and that's presumably why you are replacing them. There does not appear to be any difference in the height between the new and old where the vertical portion starts in the middle down to the bottom of the cup. Also in other words, the new ones appear to be correct. Why would you think that the new ones should look exactly the same in overall height compared to the badly compressed old one?
Old 12-19-2021, 10:13 AM   #14
fordyford
fordyford's Avatar
Looking at the photos the large upper puck is OK. Some aftermarket lower rubber has been available made to fit both early (1932/36) Small frame hole OR late (1937/48) large frame hole. You will need to cut off the smaller diameter rubber portion to make it fit in a 1940 frame. The bolt head will then be in contact with the metal washer part of the lower rubber. Problem solved.
fordyford is offline   Reply With Quote
Old 12-19-2021, 02:39 PM   #15
Pech33
Pech33's Avatar
I will check that out. I hope that is the fix. I will be at the shop tonight and take a closer look. Would have been nice if there was some directions in the package.
Old 12-20-2021, 12:08 AM   #16
Pech33
Pech33's Avatar
"You are correct sir", as Ed McMahon used to say. That is precisely the fix. This kit is from VanPelt and the bolts are 3 1/4" long. After trimming the smaller diameter piece on the grommet, it all came together. Thanks. The picture show the grommet on backwards, the smaller piece was trimmed off and goes against the head of the bolt. Works like it is supposed to.
Old 12-20-2021, 12:19 AM   #17
petehoovie
petehoovie's Avatar
Where's the cotter pin?
Old 12-20-2021, 08:48 AM   #18
Ford Freak
How tight should these be? Is there a torque for them? - F F
1952 Ford F1
!956 Fairlane Club Sedan
1965 Falcon Sprint
2007 Mustang GT
Ford Freak is offline   Reply With Quote
Old 12-20-2021, 09:54 AM   #19
Pech33
Pech33's Avatar
Laying on the bench, waiting for corn head grease to arrive. Motor has to come forward 6” to be able to “pack the u-joint”, then the motor mounts can be secured. I will tighten the motor mounts to the point of being able to get the cotter pin in and it won’t be going anywhere. They are pretty tight and still need a 1/2 to 3/4 turn to get the cotter pin in.
Old 12-20-2021, 11:34 AM   #20
JayChicago
JayChicago's Avatar
When I did this a few years ago, I was told there is no given torque spec for this bolt. I was told to get it good and tight so engine cannot lift off the rubber when working. But not so tight that the rubber is bulging, don't want the rubber compressed to a point where it can't provide some cushioning. Yeah, kinda vague.
I wonder this: Should this be looked at again now that its been a few years? Do these mounts need to be re-tightened a bit as the rubber compresses over time?
JayChicago is offline   Reply With Quote
