#1 |
I was wondering how to take the battery carrier out of the car on my 27 Coupe? I am not sure if it is damaged or not - looks like someone welded sheet metal sides to it to create a box.
"The more things change, the more they stay the same." |
#2 |
Should be 3 bolts - 2 on one side & 1 on the muffler side. One bolt should be the ground strap connection - the remnants of sheet metal don't appear to be what's left of an original Ford battery box.
#3 |
I have it loose but I can't figure out to get it out. It is in between the two frame rails and there is no space to pull it from the bottom or top. What am I missing?
#4 |
![]() Battery Carrier looking a bit worse for wear. |
#5 |
